MGW Shifter c5 or c6 shaft?
Old May 8, 2009 | 04:28 PM
CraZee ZO6's Avatar
CraZee ZO6
Default MGW Shifter c5 or c6 shaft?
hey guys which is the better shaft and why?
I am ordering a MGW shifter but dont mind for either shaft cause I am going to buy the gripper **** which is made for both styles.
I just want to know if the c6 style is better since it locks into place and not threaded like the c5..
Will post up a review when its in the car.
thanks
Zee
Old May 8, 2009 | 04:58 PM
MTPZ06's Avatar
MTPZ06
Old May 9, 2009 | 09:02 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I don't think it makes any difference whether you use the threaded or non threaded style but if I had it to do over I would go with the C6 upper handle because it is offset to the rear a bit giving a better position.
Old May 9, 2009 | 06:31 PM
CraZee ZO6's Avatar
CraZee ZO6
thanks yeah I ordered the c6 shaft.
Old May 10, 2009 | 06:57 PM
TOOGECKO's Avatar
TOOGECKO
You can also buy the C5 shaft (threaded) offset the same way...
Old May 10, 2009 | 08:20 PM
MTPZ06's Avatar
MTPZ06
Let us know how you like that C6 upper on the shifter...I'm thinking of doing the same thing.
Old May 10, 2009 | 09:21 PM
CraZee ZO6's Avatar
CraZee ZO6
sure I will post a nice review after 2 weeks of driving it.
Old May 10, 2009 | 09:41 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
For what it is worth this is my thoughts on the 2008 ZO6 shifter after installing it in my 2000 coupe. Look forward to seeing reviews from other folks.
Shifter Review
Old May 11, 2009 | 12:21 AM
The Highlander's Avatar
The Highlander
Where can you get the MGW shifter?
Old May 11, 2009 | 01:06 AM
MTPZ06's Avatar
MTPZ06
mgwltd.com
Old May 12, 2009 | 12:26 AM
MTPZ06's Avatar
MTPZ06
Shifter Review
I have driven an 09 Z06, and I most certainly liked the feel of the stock shifter much better than my 03 C5Z. Definately something to think about...I already have the MGW ****, so I could pick up the C6Z shifter for about a $100 less than the MGW. Now I'm second guessing what I want.
Old May 12, 2009 | 01:03 AM
CraZee ZO6's Avatar
CraZee ZO6
MGW is LIGHT years ahead of a stock GM z shifter even if its from a zr1 LOL...
Look at the build and parts how can you compare? Theres a reason for the price difference.
Old May 12, 2009 | 07:44 AM
Eric D's Avatar
Eric D
I find this interesting and would like to here what features the MGW has that makes it "LIGHT years" better, other then it cost more. Please give us the details.
Old May 12, 2009 | 08:22 AM
Mark C5's Avatar
Mark C5
Drive one and you won't need to ask
Old May 12, 2009 | 05:58 PM
CraZee ZO6's Avatar
CraZee ZO6
Like I said in my post.. look at both. Look at the parts used and quality of build. Use both, drive with a MGW shifter than a stock 09z, zr1, watever shifter and tell me which one is better?
Instead of making comments that serve no purpose go check it out and come back on here with your review.
Old May 12, 2009 | 06:38 PM
Eric D's Avatar
Eric D
Really! What purpose does you comment serve???
Old May 13, 2009 | 09:20 AM
PR1AWRet's Avatar
PR1AWRet
A guy asks about a MGW shifter. Now its turning into a Z06 shifter debate. I would say post your comments about what brand you like and why and leave it at that. When it turns into an argument the post is useless.
As for the MGW, I have about 5K on the new style with the C6 handle and their shift ****. It's still tight (but not new tight), shifts are precise and still like the 1" offset. It keeps my arm in a comfortable position. I also like the way I can almost shift with just my wrist.
To MGW Shifter c5 or c6 shaft?
