Hey guys drove to work today, shut car down for an hour went to start and nothing. Pulled codes and they read as follows
U1000 current
U1064 Currnet
U1160 Current
U1176 Current
Any help me fix these or tell me what is going on ? Thanks in advance guys. Is there anyway to get the car started to get it home ?
Battery seems to be good as it seems to be more of a ignition shutdown/theft deterrent issue.
Do not know if you were able to look up the codes, but it is almost like something came un plugged, lost a ground, etc??
let us know what you find out!
U1000 Loss of Communication Undetermined
U1064 Loss of Communications with BCM
U1160 Loss of Communications with LDCM
U1176 Loss of Communications with RFA
Many thanks to Bill for walking me through the fix. Turns out my Air conditioner was backing up with water leaking water right down on the BCM which was wreaking havoc on my electrical system. Dried out the bcm and connections, reset the codes and fired it right up. Many thanks to the Guru !!!
