help needed for a uk corvette owner!!
Old May 15, 2009 | 02:35 PM
kawasakih2's Avatar
kawasakih2
3rd Gear
Default help needed for a uk corvette owner!!
i have a 2000 c5 corvette, i went over a bump a couple of weeks ago and the traction control and active hangling an abs lights all lit up on the dash and stayed on till i turned the car off,
they stay off til i go over a bump again,
it also lights up service abs, service traction control and service active handing
i have checked the fault codes and tryed deleting them but they keep coming back on here are the codes that are coming on:
28 TCS (2 CODES) :
C1222 H
C1226 H
Can anyone give me some advice on what to do, beacuse over here in the uk there are not many corvette specialists so they dont no what there dealing with,
a friend has told me it is a abs sensor, dont want to be ordering one of this from America and finding out its not that,
is there anything that i can do to make sure its that before i buy one,
many thanks
william
Old May 15, 2009 | 02:45 PM
MagRedConv's Avatar
MagRedConv
Do a quick search on diagnostic codes, you'll find a complete list and can go from there. Also, you might want to PM Dee Gee, he's in the UK as well and may have insight on which vendors to order from.
Old May 15, 2009 | 03:04 PM
Hrdtop00's Avatar
Hrdtop00
28 TCS (2 CODES) :
C1222 H
C1226 H
many thanks
william
Here you go. Good luck.
• C1222 RF Wheel Speed Sensor Input Signal is 0
• C1226 LF Excessive Wheel Speed Variation
Old May 15, 2009 | 03:14 PM
poolboy's Avatar
poolboy
first thing to do is to check those wheel sensors and make sure they are well connected - they should be the only electrical connection you see going into the wheel hubs. Pull them apart and make sure they are clean and tight.
Old May 15, 2009 | 03:19 PM
kawasakih2's Avatar
kawasakih2
3rd Gear
thanks will go check them wires now, if its not the wires what else can it be??
thanks
Old May 15, 2009 | 04:44 PM
kawasakih2's Avatar
kawasakih2
3rd Gear
just checked all the wires seem ok, taken them all out an cleaned them up not like they needed it tho, so dont know what to do now can anyone help please??
Old May 15, 2009 | 09:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Lets see,,,,,I wonder if Ive ever been down this road before??
You have a poor wheel speed sensor wiring harness connection and its going to be in one of the female connector pins.
Check BOTH sides but,,,I'm only going to talk about one front wheel.
The wheel speed sensor (WSS) is pretty much bullet proof. Short of bearing failure or damage from an accident,,,,I have never seen a WSS fail.
Heres a front sensor:
You need to check EACH female pin. To do it correctly, you need a MALE pin like this. I got one out of a defective switch:
Each female connector has two female pins. The tensioning arm in the pin spreads and causes a poor connection. If you insert the male pin into the female pin,,,there should be a nice tight grip on the male pin as you insert and remove it. here is an example of a brand new female connector and a BAD old connector:
Bad on the right,,,,good on the left:
I have learned that you can use a dental pick to bend that tension arm down and restore tension. If you cant do that, you will have to replace the PIN or the entire connector:
There is a JUMPER HARNESS that connects the hub to the chassis connector. That female pin often goes bad. The female pin in the chassis connector went bad in mine.
JUMPER CONNECTOR
BC
Old May 16, 2009 | 01:01 PM
cliff_ford's Avatar
cliff_ford
Most code lists have C1225 and C1226 reversed. C1226 is in fact the right front.
So looks like your right harness has dodgy female pins as Bill says. Bill led me there a few years ago.
Good luck,
Cliff (also in UK)
Old May 16, 2009 | 03:00 PM
SJPD's Avatar
SJPD
there is an H
doesn't that mean they are History and don't really matter ?
Old May 16, 2009 | 03:16 PM
cliff_ford's Avatar
cliff_ford
Originally Posted by SJPD
there is an H
The harness is usually intermittent, so the fault clears.
To help needed for a uk corvette owner!!
