TFS 215 Pushrods
I tried a rough check and did a comparison on my comp cam pushrod checker for overall length. I set it to between 10 1/3 - 10 1/2 turns which is what we averaged between intake and exhaust. I then locked it down at that length with electrical tape. I will still take it to a machine shop for proper measurement. With adding 0.040 preload I measured 7.39" by using two bolts stacked end to end with a nut that I adjusted to get exact length. I then measured the two bolts seperately with my 6" caliper. This roughly compares to the 7.36 using the comp checker. I will give you the final accurate result tomorrow!
The overall length ended up being 7.330".
When I add my 0.040" lifter preload that gives me 7.37" pushrods.
If I would have gone by the comp cam pushrod guidelines I would have ordered 7.36" with the same 0.040 preload.
I will be calling Manton this morning and placing my order!
It's not that one was wrong or right...it's just using a different form of measurement. If you ordered a Comp pushrod for example, 7.358" would be correct...Manton wants overall length, and 7.375" is correct for that. Either way you'd get the same length part.
Does anyone ever order the 16oz?
Oh, pushrods. Yeah...you want them as stiff as possible. They do deflect in operation , and minimizing that deflection is good. Good for better valve control, good for high RPM stability, good for reducing valvetrain harmonics.
Adding stronger valvesprings, larger-heavier valves, increasing pushrod length, increasing RPMs, are all things that will cause a pushrod to deflect even more.
Of the various ways to combat deflection (stronger material, thicker wall, bigger diameter)...Increasing diameter (by far) makes the most difference.
There's nothing inherently "wrong" with your .080" wall 5/16" chromoly pushrods, they are a definite improvement over stock...but they are kinda like that 16 oz beer...pretty good, but not the best when you have the option to go bigger.
Simply put, run the biggest dia. pushrod you can fit, and enjoy a more stable valvetrain.
how much were the 3/8 pushrods Verne?
heres the measurments i took with my checker 7.4875 intake at zero lash 7.500 exhaust at zero lash
bore of my TFS pushrod hole per my fancy measurment (stuck different size 1/4 inch drive sockets in till i got a snug fit then used the calipers) was .450
with a the following pushrods you get this clearance:
5/16=.3125 .450-.3125=.1375/2= .0688" clearance on either side of the pushrod assuming pushrod is centered in bore
11/32=.3438 .450-.3438=.1062/2=.0521 """""""""""""""""""""""""""""""""""""""" """""""""""""""""""""""
3/8=.375 .450-.375=.075/2=.0375................................. .......
yes i have the clearance assuming all is centered but we all know as a rocker works it pushes and pulls the pushrod away from and toward the valve as it works its motion
Im going to bet i only have room for a 11/32...
Talk with Terry "the man" Manton today....just the OD change of the 5/16 pushrod to a 11/32 increases strength by 50%...he only stocks 1 wall thickness of 11/32 rod and its .120 wall this increases strength by an additional 9-10% so if I go to a 11/32 manton 3 piece pushrod it will be approx 60% stronger than my current comp magnum 5/16" .080 wall chromoly pushrods
now if i could run a 3/8" you damn well better believe i would...its lighter than the 11/32 120 wall model due to only having a .080 wall yet 2 times stronger than the .080 wall 5/16 model
so as Y2Kvert puts it...i dont get my 16 oz glass of beer and i cant get my 24 oz....my motor should be satisfied with the 21oz glass of beer haha
now the question is what length should i go with
now i understand Manton wants overall length and this supposedly is different from gauge length...but when i measured roughly the 7.500 length i came up with by the gauge reading...i stood it up on end next to a scale and sure enough lined right up with the 7 1/2 inches
im thinking 11/32 7.540" .120 wall 3 piece pushrods this by my calcs should give me .0525 intake preload and .040 exhaust preload assuming measurements were correct...currently running comp magnums 7.550 (this offered 5/8 to 3/4 turn of preload, does that sound right then for my measurents?)
random question...if i compress a cylinder with air and it shoots it to BDC (all plugs are pulled and im changing valvesprings) which cly will be TDC easy access cylinders for pushrod measuremend would be 4, 6, 1, and 2 which cyls would have to be at BDC for those to be TDC
Thanks for the help guys...hope i have one stable *** valvetrain after this swap
3/4 turn is (1.25 X 3/4)/25.4 X (2.7/1.7) = 0.058" per my calculations. 5/8 turn is 0.049".
Overall Length is approximately 0.017" shorter than gauge length. Do you have an 8" vernier?
