TFS 215 Pushrods
Old May 16, 2009 | 10:27 AM
vsocks1's Avatar
vsocks1
Default TFS 215 Pushrods
Just thought I would see if anyone has run larger pushrods with TFS 215's. Wondering if anyone is running 3/8"? I plan on putting the heads on today and measuring for length. Will order some from Manton on Monday. Thanks!
Old May 16, 2009 | 11:36 AM
baezi z06's Avatar
baezi z06
yes have 12 piecies, but i´m here in iceland
so it is long way to pick them up....
Old May 16, 2009 | 04:11 PM
zeevette's Avatar
zeevette
As far as length goes, I believe the recommended size is 7.5" on the second generation TF. Mine are 7.9" and I was required to use full roller rockers. PRs were included in my package, and IIRC, they were 3/8".
Old May 16, 2009 | 06:07 PM
vsocks1's Avatar
vsocks1
We measured the length on mine today with Morel Lifters.
Cam was on base circle and used comp cam checker at zero lash:
Intake 7.358 with 0.040 lifter preload
Exhaust 7.365 with 0.040 lifter preload
Need to decide on length & preload and verify I can run 3/8" pushrods.
Help - Vettenuts!!!
Old May 17, 2009 | 08:43 AM
vsocks1's Avatar
vsocks1
Calling Bob (Vettenuts)....would like your thoughts!!
Old May 17, 2009 | 09:56 AM
vettenuts's Avatar
vettenuts
Not sure on your question but for information the Morels are taller than stock GM and therefore the pushrod length over those normally used will be shorter. Also, the reduced preload will shorten them as well. In the end, rough numbers, the use of Morels will shorten pushrod length by approximately 0.100". Using that apporximation, you can see that GM lifters would have put you near Zeevette's recommended length.
Can't answer the question on the 3/8" pushrod, but he also can make an 11/32" diameter is you are concerned with the 3/8". He will also sell you one so you can check it prior to ordering a set.
Old May 17, 2009 | 10:02 AM
vsocks1's Avatar
vsocks1
Well, just mostly wanted your opinion on preload and what length I should ask for. Should I run the same length on both intake/exhaust as we measured slightly different?
Old May 17, 2009 | 10:12 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I'm 99% sure he will be able to fit 3/8"...just by comparing the hole size between the heads, the TFS are drilled considerably larger than his stock 243s.
That would be the only limiting factor correct?
(I think he is awaiting a definitive answer from TEA too).
Old May 17, 2009 | 07:43 PM
vettenuts's Avatar
vettenuts
7.4's look like they will work in length unless you want to him them dead nuts, then you need custom length and if you do, Terry Manton works off of Overall Length, not gauge length.
Old May 17, 2009 | 07:48 PM
vsocks1's Avatar
vsocks1
If I had 7.4's wouldn't I have like 0.80 preload on my Morels? So how do I convert my gauge length to overall length?
Old May 17, 2009 | 09:16 PM
vettenuts's Avatar
vettenuts
Me bad, I re-read your post, didn't notice that you already had the preload in the numbers when I read it the first time.
Old May 17, 2009 | 09:27 PM
vsocks1's Avatar
vsocks1
So should I just ask for 7.36" for both intake/Exhaust? How do I convert that to overall length to make sure I get what is needed?
Old May 18, 2009 | 06:26 AM
vsocks1's Avatar
vsocks1
Here is a picture of my TEA TFS 215's. From what I understand they started machining them for larger pushrods within the last 6 months or so.
Here is a picture of the underside:
Old May 18, 2009 | 07:23 AM
vettenuts's Avatar
vettenuts
Best way is to use an 8" vernier if you have one. In general, the length difference is approximately 0.017" however since you have such a narrow range of preload on the Morels you really need to ensure it is correct. You could call Manton and speak with them as well.
I am thinking seriously of doing a pushrod swap to the 11/32" OD pushrods. If I do, I am going to call Trend and order one pushrod in my current length so I can measure it accurately or I just may send it to Manton and tell them what I need so they can measure it.
Old May 18, 2009 | 07:43 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
If the Comp measuring tool references gauge length...then 7.375" is what would be needed for actual length.
Old May 18, 2009 | 09:36 AM
vsocks1's Avatar
vsocks1
I called Mike from TEA and he verified that I can run 3/8" pushrods!
Old May 18, 2009 | 09:54 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Depending on when you get them, I may have to bring my car back and tear off a valvecover and rocker to see if they'd fit in my heads.
To TFS 215 Pushrods
Old May 18, 2009 | 11:00 AM
vsocks1's Avatar
vsocks1
That would be fine - maybe we should just throw your rockers on then too!!
Old May 18, 2009 | 11:10 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
The rockers will likely change what I need for pushrod length, but I s'posse it would be a good time to mock one up and check for proper length too.
If I change pushrods, the rockers are definitely going on...I'd just really like to know if I could fit a 3/8", and having access to one and trying it would be the quickest way to find out for sure.
Let me know what you end up buying from Manton.
Old May 18, 2009 | 06:25 PM
vsocks1's Avatar
vsocks1
Bob (Vettenuts) was right once again! Terry Manton wants me too measure overall length on the pushrod checker. I will go to a machine shop tomorrow morning. If I call Terry in the morning he will have them out later in the day! Spent a good deal of time talking with him about my setup. He said with my spring pressure, rockers etc. he recommends 3/8" diameter with 0.095 wall thinkness and 5/16" ball ends. He said I didn't need tool steel ball ends. Their pushrods are 3 piece - the column and two ends press fit on. The custom pushrods we discussed will be less than $200 plus shipping. Not too bad for great product and service!
Hopefully they are ordered tomorow am!!
