"reduced engine power" hypertech
Old May 17, 2009 | 12:50 PM
chrisbenoit's Avatar
chrisbenoit
Default "reduced engine power" hypertech
I just bought a 99 FRC recently. It came with a Hypertech programmer. I read the booklet and decided to plug the programmer in. Right away it started reading the current program in my car. It reached 99% and the alarm in the car started beeping and the DIC read "reduced engine power" I was then prompted to turn the ignition off and unplug the programmer. I took the car for a drive and it doesn't seem like I lost any power but I may have a whining noise coming out of the motor. The noise may be because the motor wasn't really warm. Should I be alarmed or is this normal? Any help is appreciated.
Old May 17, 2009 | 01:15 PM
lucky131969's Avatar
lucky131969
May be coming from the motor? Can you isolate the noise?
You should not have any whining noise at all, regardless if the engine is warm or not. Does it go away, or is it constant? You will have to be more specific. For all I know, what you are hearing is the AIR pump turn on.
Old May 17, 2009 | 01:46 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
When flashing tunes into the PCM, it's fairly normal to see that message on the DIC. (I usually see it too when flashing a new tune in with EFI Live).
If you were really in Reduced power mode with the engine running, believe me, you'd notice the profound difference.
Old May 17, 2009 | 01:55 PM
chrisbenoit
Thanks for the help. As for the noise "whining" I just took the car for a drive and the higher gear I go the quieter the car is. It is barely noticeable in 5th, and can't hear anything in 6th, gear. Car is shifting fine and behaving as normal. I just recently bought the car so maybe I just noticed the noise today but I doubt it. Any ideas?
Old May 17, 2009 | 02:19 PM
Z06Fanatic's Avatar
Z06Fanatic
Maybe it installed a supercharger??
To "reduced engine power" hypertech
