Damaged G5x3 cam... has lobe damage
Old May 19, 2009 | 07:39 PM
Jesse_Boyer's Avatar
Jesse_Boyer
Default Damaged G5x3 cam... has lobe damage
I had to pull apart my built LS1 due to a faulty ring problem and much to my surprise, I found a damaged lobe on my LG G5x3 cam. The lifters have absolutely no marks indicating they were the problem. This cam was bought new from LG and doesn't have many miles. I have the receipt from the previous owner (dated 10-16-06).
Has anyone had this type of issue (with any cam, regardless of manufacturer/vender?)
I have not contacted LG yet.
edit: very large pictures attached.
Old May 20, 2009 | 07:45 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Any photos of what the damage looks like? What was wrong with the rings?
Old May 20, 2009 | 09:08 AM
Jesse_Boyer
it's a very mild 'marring' of the lobe surface. I'll try to snap a picture tonight.
Truth be told, I'm not even certain it's the rings. The motor was using about a quart of oil per 200 miles (if not more). I have little oily spots covering the rear fascia, and it bellows smoke on a hard acceleration as well as when I shift. I've only driven it about 500 miles since buying last year. (Had to replace a pilot bearing last fall, then it was winter before I knew it. Since I decided to pull the motor early April, it's been on jack stands more than it's been on the wheels!) Regardless, I did a compression test and all cylinders came back around 175psi or so, accept for the one odd-ball at 200-ish (numbers from memory, don't have the sheet in front of me). Then, after adding a dab of oil and running the tests again, I found the numbers jumped to around 220-psi on all cylinders. My research told me it was the rings at that point...
Old May 20, 2009 | 09:39 AM
Billdog350's Avatar
Billdog350
Jesse, if you haven't put many miles on that car, its possible that your knockout plug on your crank was damaged when the pilot bearing was replaced! Many people don't know about the hollow crank on the LS1 and use the old method of cramming grease or wet toilet paper into the hole and then using a dowel to press out the bearing. Using that method will distort or break the knock out plug on the crank and then you'd be spitting oil out the back of your motor!
If that's not the issue, you might have a plugged or manfunctioning PCV system which would dump a lot of oil into the combustion chamber under hard acceleration.
I can't remember my PSI on my 1997 but I think it was in the 175 range too with 120,000 mi on the rings and new LS6 heads. That motor put down 412/396 to the wheels with the ported LS6 heads and G5X1 style custom cam so I think the bottom end is fine.
Old May 20, 2009 | 02:30 PM
zeevette's Avatar
zeevette
Re: your cam damage....LG uses Comp cams, I believe, and a few years ago they had a bad run of cams that kind of delaminated on the lobe surface. Might be related?
Old May 20, 2009 | 03:29 PM
lucky131969's Avatar
lucky131969
If you did not install the cam, how do you know what happened on the install? Post pics of the suspect damage.
Old May 22, 2009 | 05:04 PM
Jesse_Boyer
that will be a relief and a huge disapointment at the same time. Took a bit of effort to get the mill out of the car and I haven't been driving it at all. Needless to say... I'm still having it torn down to find out if anything is wrong.
If the knock out plug has been compromised, this wouldn't cause the motor to use oil during combustion. Rather, this would cause an oil leak, correct?
Definitely interesting information. I'm uploading pictures now. They're all quite large and I have to get to a 4:30 apt now. So, I'll post the pictures later.
Regardless of whom build the motor, how does anyone know if it's ever the manufacturer or the installer/builders fault? Just a thought...
Old May 22, 2009 | 05:57 PM
chriswtx's Avatar
chriswtx
Looks like the same problem as the bad cams had from Comp Cam..
Old May 22, 2009 | 09:46 PM
Jesse_Boyer
Is this something that LG or Comp Cams will stand behind? What happened to all the others that had cams with this type of wear?
Old May 22, 2009 | 09:47 PM
chriswtx's Avatar
chriswtx
I would go through LG first since its there cam..
Old May 23, 2009 | 12:50 PM
zeevette's Avatar
zeevette
Looks like you've got pitting on the bearing surfaces as well. You might want to consider a new shortblock.
Old May 23, 2009 | 01:10 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I have another X3 cam that looks just like that, there are numbers on the cam, I will post them.....
not the end, but also between the lobes
to the above poster, I think the cam journals are fine, looks like dust/lint to me
Old May 23, 2009 | 01:58 PM
Eric D's Avatar
Eric D
Just seen your photos. Yep, pretty bad. If you haven't already checked, look over the carrier for the lifter of the bad lobe. I have seen where they allow the lifter to rotate to the point where the roller skids instead of tracking true to rotation. If you don't find this to be the cause, then most likely the heat treat of the lobes was improper. I hope LG or who supplied the cam will stand behind it for you.
I agree with Steve, the cam bearing surface looks fine to me.
Keep us posted on how things go.
Old May 23, 2009 | 02:46 PM
SteveDoten's Avatar
SteveDoten
I've NEVER seen the twisted lifter..............but sure have read it a lot on the forum
anyone have pics of that????
Old May 23, 2009 | 05:30 PM
T.J.'s Avatar
T.J.
I was recently looking at buying a cam that looked like this. I called LG and was told that comp cams is the company to talk with and see if it could be regrinded. I called comp cams, and they asked if I bought the cam through them and I told them no, that I was looking to repair a cam. In short the answer was that they would no fix the cam since it was not purchased through comp cams. I called LG back and they said if comp made that statement then there was nothing they could do for a repair. This story could be different for you since you've pruchased the cam from LG. Good luck
Old May 23, 2009 | 05:48 PM
thehammer69's Avatar
thehammer69
This is why I always recommend buying a cam from Comp directly. You may pay an extra 25 dollars, but you won't have to go through somebody to get extra customer service or to get extra services done.
Old May 23, 2009 | 07:32 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Correct me IF I'm wrong, but Comp is out of business! I had some problems wiping lobes with Comp Cams a few years back.
To Damaged G5x3 cam... has lobe damage
Old May 24, 2009 | 04:23 AM
zeevette's Avatar
zeevette
I think Comp is still around.... but Crane is DOA.
Old May 24, 2009 | 02:05 PM
chriswtx's Avatar
chriswtx
Crane cams DOA.. Comp Cams still going strong..
Old May 24, 2009 | 02:29 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Do you have adjustable rockers?
