1998 keyless entry question
Old May 22, 2009 | 10:06 AM
tonycorvettes's Avatar
tonycorvettes
Default 1998 keyless entry question
i just bought a 98 cvt and got no key fob,the guy owned it 9 years and didn't think it comes with it.i think it did and he just didn't know vettes,,in options it shows to turn off passive,,dont you think i can get a fob and program it?can someone direct me to the instructions and maybe know the option,for remote entry,didnt all 98 come with remote entry?
Old May 22, 2009 | 10:56 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Yes all '98's came with keyless entry. Here are the programming instructions:
1. Turn the ignition key to ON.
2. Clear any warning messages on the Driver Information Center (DIC) by pressing the RESET button.
3. Press the OPTIONS button on the DIC several times until the blank page is displayed, then press and hold the RESET button for two seconds.
4. When the message FOB TRAINING is displayed, push the RESET button once. The message HOLD LK + UNLK 1ST FOB in the DIC will be displayed.
5. Press and hold the LOCK and UNLOCK buttons on the transmitter simultaneously for 15 seconds.
6. When a transmitter is learned (matched), the DIC will display FOB LEARNED and then prompt you to learn the next transmitter.
7. Repeat Steps 5 and 6 for each additional transmitter.
8. Remove the key from the ignition.
Old May 22, 2009 | 11:26 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your Key FOBs are EXPENSIVE!
There is an upgrades for the FOB and Tire pressure transmitters. You basically install a 2001+ RFA and order 2001+ fobs and tire pressure transmitters.
If you order the early style FOBs,, I recommend getting new because they do go bad over time.
You can program up to THREE fobs for you car. On the door you will see Mem -1 Mem- 2 and if you press Mem -1 & Mem- 2 that will give you a third memory.
Old May 22, 2009 | 04:45 PM
dancin1's Avatar
dancin1
Default Key Fobs.
Man they are really, read that as REALLY expensive ! I got just one with my '98 coupe and it didn't work. I found that the ones for the '98 &'99 are the most expensive and I hear it's because of that passive feature. I replaced the battery, then re-learned them to the car, then did it many more times and it still didn't work right till I read on here about a way to fix them once and for all. The guy used a soldering iron to solder the battery points back to the circuit, and said you could use super glue. I was at the point of throwing mine away, and since my hands aren't so steady with the age factor, I used the super glue and it's worked very well ever since. This place is great for people to share information. Especially Bill above. When he says something, he's right !
Old May 22, 2009 | 05:09 PM
ABNVET.I's Avatar
ABNVET.I
I upgraded mine and have less money in the 4 tps, transmitter and the 2 new FOBs then I could have bought new FOBs for Very easy to switch out.
Old May 22, 2009 | 05:18 PM
Mark C5's Avatar
Mark C5
GMPARTSHOUSE (Gene Culley) has them for $78.00
http://www.gmpartshouseusa.com/partl...layCatalogid=0
Old May 24, 2009 | 11:25 PM
tonycorvettes
Default thanks
for the info
Old May 28, 2009 | 12:05 AM
squidwards vert's Avatar
squidwards vert
Use the 2000 fob and never look back at the passive feature, its a PITA anyways IMO.
I use a 2K fob on my 98 every day, no problems and they are cheaper then the 97-99.
To 1998 keyless entry question
