DIC codes
Old May 22, 2009 | 04:06 PM
mark_03ZO6's Avatar
mark_03ZO6
Default DIC codes
I have a few codes that came up today. I know there is a place on here that tells you what each means, I just can't find it. Can anyone help? The codes are U1064H and PO171H. Or if you can just give me the link to where I can look them up myself will be good too. Thanks
Old May 22, 2009 | 04:36 PM
dancin1's Avatar
dancin1
DIC codes...you can look them up at www.stengel.net/dicodes. That was from the good folks here on the forum to me awhile back. The codes you got are history codes:H. That means they happened in the past, if the code was followed by a C it would mean it was a current code. P0171H=Fuel trim system lean bank 1/history. U1064H=Loss of communication with BCM/history. You need a Corvette service manual to look up and decide what to do about them. You could look each up and it would give you a detailed outline for testing to find the trouble. Except yours are history and not current.
Old May 22, 2009 | 07:42 PM
mark_03ZO6's Avatar
mark_03ZO6
Tried the link, couldn't get it to work. Thanks for the info though.
Old May 23, 2009 | 10:14 AM
87SAM's Avatar
87SAM
This link should now work http://www.stengel.net/diccodes.htm
The following link has troubleshooting info for the PCM
http://gearchatter.com/viewforum44.p...576d267a70779b
To DIC codes
