I was just finished installing my long tube headers when I pulled out the IAT wires right out of the plug. Can someone please show me a picture of there's or tell me which color wire goes to which side of the plug. One wire is purple one is tan .
Quick note of thanks for this thread. My 99 showed all these same symptoms. P0113 P1111 and active handling light stayed on. The fix was repalcing the connector for the IAT.
Thanks All!
I know I know I am reviving an old post.........my c5 has the wire broken going to this plug which of course is causing the CEL to come on. I tried to repair the wire but it is too brittle and broke off when trying to strip the insulation off. I know C5Lur'r posted the picture of the connector but does anyone have a part number by chance? I looked at the 2 places he mentioned but on Bellanger it shows the connector as being a 4 wire and I couldn't find it on the other link he posted
EASY.. Call Gene Culley at CULTRAG Perforance and talk to Gene or Patrick. They can get that connector and you can splice it in.Bill
You can also DE PIN that connector and solder in some new wires and make your own pig tail. Just use a very small pick an press down the retainer pins on the pins and they pull out.
