Headliner issue
Old May 29, 2009 | 03:00 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Default Headliner issue
The headliner on my 2000 coupe targa top is becoming unglued. The headliner itself is in excellent condition but it is separating from the top. Does anyone have any experience with regluing the headliner to the top? Any help would be appreciated. Thanks.
Bill
Old Dec 16, 2009 | 07:17 PM
YellowFlash's Avatar
YellowFlash
CI 7 & 9 Veteran
Default Anyone know how to disassemble the targa top?
Old Dec 17, 2009 | 09:25 PM
tlgarst's Avatar
tlgarst
I have a vert, but if the headliner is like the one in my 99 olds the cloth is okay, the issue is the foam backing has turned to dust.
What I do is go get some headliner material ( JoAnn Fabrics) and remove the old headliner and clean the backing.
The backing is cardboard in a car but I'll bet it's fiberglass in the vette.
So you take a stiff brush and clean off all the old foam / dust, and spray down some automovtive glue ( get it at Walmart in auto dept).
Carefully roll the new headliner material onto the top, trim and you are done.
I have not looked but most likely there are directions to replace a headliner in a non vette out on the net.
Just to give you a DIY cost in a non vette is about $30, I would think a vette would be less because you would need less hedliner material.
Tim
Old Dec 19, 2009 | 04:47 PM
Johnny Hardcore's Avatar
Johnny Hardcore
The foam didn't turn to dust, and there is no cardboard...but there is what seems to be a fiberglass like backing, previously mentioned. The liner falls because there is a cheap plastic liner over the "fiberglass" foam like material, and it rips and seperates.
Pull the liner out from one of the corners and peel it like a fruit roll up. Then use a razor and remove the ripped plastic liner. Take a cheap can of spray edhesive from Walmart, Target etc. Spray directly on the roof panel and directly on the "fiberglass" backing. Let it set momentarily until tacky. Then put the liner back in, starting with one side, making sure you run your fingers over it and smooth it out while you work your way down to the other end.
If you dont remove the clear plastic... the liner will fall again. Ask me how I know.
Very simple and it's held up for me for over two years now.
Old Apr 22, 2011 | 02:18 AM
Black$heep's Avatar
Black$heep
Bill
http://forums.corvetteforum.com/c5-g...cha-think.html
Old Apr 22, 2011 | 10:21 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Wow! Great Job! Talk about CUSTOM!
Old Apr 22, 2011 | 11:24 AM
alxltd1's Avatar
alxltd1
It is very cool…..talk about resurrecting an old post (12/2009) from the dead….oops, it is Easter!
To Headliner issue
