aic conditioner leak
Old May 30, 2009 | 07:00 PM
rollinred's Avatar
rollinred
Default air conditioner leak
Have anyone ever had a leak that they repaired? please tell how this was repaired thanxs
Old Jun 2, 2009 | 10:37 AM
bighank's Avatar
bighank
Default Check O rings usually the culprits.
Shrunken O rings are generally the cause of a freon leak.
Sometimes you just have to tighten the connections a little. I've also had bad schrader valves (like tire valves on the high and low side of the freon lines). If these are leaking discharge and evacuate system and recharge after replacing the valves.
To find the leak use some freon with dye in it.
BIGHANK
