Optima battery question
Old Feb 7, 2002 | 08:38 PM
btsoom's Avatar
btsoom
Default Optima battery question
Can I use a blue top or do I have to use a red top ( I heard the blue was for marine use, but is there a big difference in specs that it won't work) ?
Yes, my car is blue.
Thanks...
Ken
Old Feb 7, 2002 | 08:48 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Default Re: Optima battery question (btsoom)
btsoom,
Sorry, you can't use the blue top as it is designated for marine use only and the C5 has side post terminals that the blue top does not have.
The blue top only has dual TOP posts only which are mainly used for boats.
Shawn
Old Feb 7, 2002 | 09:07 PM
btsoom's Avatar
btsoom
Well, there goes the color scheme :(
I'll stop by the mall and order up a red top. Thanks shawn.
Old Feb 7, 2002 | 09:58 PM
LT1GMC's Avatar
LT1GMC
The new Delco AGM battery like used in the '01's and up is a similar type design(not round cells but the no liquid type), and is a couple of pounds lighter than the Optima.
Old Feb 7, 2002 | 11:53 PM
jefffxdwg's Avatar
jefffxdwg
btsoom,
Check out LAPD's special in the G.P. section, $110.00 delivered to your door, FAST. Its a great deal.
Jeff
Old Feb 8, 2002 | 12:14 AM
borba's Avatar
borba
Default Re: Optima battery question (jefffxdwg)
Your local Cosco store should have the red tops for $99.00 :D
Old Feb 8, 2002 | 12:21 AM
99 Corvette's Avatar
99 Corvette
A red top and the Krylon touch might work :smash:
Jerry
Old Feb 8, 2002 | 12:28 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Optima battery question (99 Corvette)
Marine batteries are deep cycle designed batteries and will not last as long as a regular car battery if you use them in a NON-Marine application. GO WITH THE RED TOP.
Old Feb 8, 2002 | 12:55 AM
2001roadsterNBM's Avatar
2001roadsterNBM
Default Re: Optima battery question (Bill Curlee)
what about yellow top. what is the difference between the yellow and red. TIA! :seeya
Old Feb 8, 2002 | 02:48 AM
borba's Avatar
borba
Default Re: Optima battery question (2001roadsterNBM)
Red top is for normal use and is recommended for daily driving.
Yellow top is deep cycle and can be used for daily driving and keeps the battery charged better during long period of not driving the car. If you drive the car on a normal basis or just even weekends buy the red top and you will like it. :yesnod:
To Optima battery question
