T-stat question...retrofit?
Old Jun 5, 2009 | 10:54 AM
MTPZ06's Avatar
MTPZ06
Default T-stat question...retrofit?
I have an 03 C5Z...and as you all know, the T-stat is integrated into the housing and they cost about $60. On the 04 C5Z, the T-stat and housing are separate, just as they are in the C6's, and cost about $20 to replace. Can I retrofit an 04 C5Z T-stat housing to my car in order to run the $20 replacement T-stats? Is it a straight bolt on, or is there more to it?
Old Jun 5, 2009 | 11:58 AM
vettenuts's Avatar
vettenuts
What's wrong with the stock thermostat?
Old Jun 5, 2009 | 01:32 PM
molson's Avatar
molson
Why not just run an LS2 or newer water pump ?
Old Jun 6, 2009 | 11:13 PM
MTPZ06's Avatar
MTPZ06
Good questions...just does not answer mine.
Old Jun 7, 2009 | 01:52 AM
avenged_motorhead's Avatar
avenged_motorhead
I paid $36 for my 160* thermostat, where are you buying a thermostat from?
Old Jun 7, 2009 | 07:35 AM
416 Rigby's Avatar
416 Rigby
Default Also a TS question
I replaced a '98 water pump with a new (GM) pump and the 160 TS that came with my Novi kit wont fit into the cavity in the new pump.
What's with that?
Old Jun 7, 2009 | 09:35 AM
vettenuts's Avatar
vettenuts
I asked mine because the stock unit is very easy to tune and open/run at lower temps. If you are simply seeking for it to open at a lower temp than that can be accomplished for about $1.
To T-stat question...retrofit?
