Replacing sway bars..... lessons learned
Jun 20, 2009 | 05:02 PM
changing sway bars is one of the easiet things to do if you have proper tools
Jun 20, 2009 | 10:25 PM
What is best lube to use on sway bar bushings?
Tried some silicone grease, but both bars started squeeking after a few miles.
thanks
Jun 20, 2009 | 10:35 PM
Does anyone know if it is necessary to remove the wheels if you have a Kwik-Lift to drive up on?
Jun 20, 2009 | 11:35 PM
Quote:
Originally Posted by
22vette
thanks
I like NAPAs Sil-Glyde.....just like this but in a NAPA blue tube
http://the-auto-alley.amazonwebstore...B000KXLR5E.htm
A non-melting, non-freezing, non-gumming and weatherproof, lubricant effective from -20°F to 600°F!
Jun 21, 2009 | 12:30 PM
Premium Supporting Vendor
To answer your question, I don't think the nuts should be all that difficult to turn. That doesn't sound right.
I'm glad everything worked out!
Jun 21, 2009 | 02:49 PM
Choreo
it's easier but not entirely needed depending on your tools
Jun 21, 2009 | 04:49 PM
22vette
thanks
I use Antisieze on my sway bar bushings..... it`s impervious to heat and water, to this day I have yet to have to re-grease the bushings...
If you don`t believe me....get some on your hands and try and was it off!
Jun 21, 2009 | 04:52 PM
Rag-Top Rick
Is the Antisieze safe for rubber ?
Many lubes will soften rubber............
Jun 21, 2009 | 08:05 PM
jrprich
Never had any issues....these days I run poly for the additional performance...
Jun 22, 2009 | 10:51 AM
I did Z06 Springs with my Z51 bars, so that made the bars seem like a breeze. It was also 1 million degrees in my garage last summer when I did it. I had to drink water for 3 days straight before I could taste salt.
Jun 25, 2009 | 01:27 PM
How does she feel with the C6Z51 bars vs your old C5Z51 bars?
Jun 25, 2009 | 01:48 PM
BUGZ
Just did a 500 mile trip with a decent section of twisties. Less body roll in the corners. So far not a huge difference, but better.
Jun 25, 2009 | 03:28 PM
But I did begin to notice a bit of "clunking" from the rear bar after this trip.......searching it seems that loose end link nuts are what everyone sways.
I will try to torque them down to 53ft.
1974 ,
2004 ,
bar ,
bars ,
bushing ,
c5 ,
corvette ,
grease ,
hours ,
labor ,
link ,
nuts ,
rear ,
replace ,
replacing ,
sway ,
video
