Trouble codes and c4c5 response
Old Feb 10, 2002 | 11:58 AM
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
Default Trouble codes and c4c5 response
Any input is appreciated.
c4c5 answered these trouble codes for me:
To: PAUL E KOERNER
Sent: Sunday, February 10, 2002 8:34 AM
Subject: Re: DTC codes
10 pcm p1870 hc
28 tcs v1000h
58 sdm v1016h
v1000h
Response from c4c5:
Ok, your 1870 is the issue.
This is a torque converter slippage code for one of several reasons.
first, the calibration that was done did not take, and therefore, the computer sees different rpm vs speed readings, therefore, sees 'slippage', which sets the code.
Second, your Torque converter clutch hydraulic control solenoid is bleeding off fluid pressure, and the converter clutch is not holding.
Third, you may have a defective converter itself.
I would talk with MTI, and see when they can look at it, because your vehicle is so new, I would say that it is a component issue, with the parts installed.
I am sure that you are aware, you have no further warranty on the driveline, in any way.
Please keep me posted, c4c5
----- Original Message -----
