Roller Rocker Wipe Pattern
Old Jun 26, 2009 | 12:47 PM
geezel's Avatar
geezel
Default Roller Rocker Wipe Pattern
If I go with roller tip rockers (i.e. YT's), does a good wipe pattern necessarilly equate to proper push rod length?
Old Jun 26, 2009 | 12:56 PM
vettenuts's Avatar
vettenuts
No. You should set wipe first, then measure for pushrod length.
Old Jun 26, 2009 | 04:50 PM
voda1's Avatar
voda1
Link to setting wipe: http://forums.corvetteforum.com/c5-t...e-pattern.html
Old Jun 26, 2009 | 05:51 PM
geezel's Avatar
geezel
How about setting wipe with heads on the car?
Old Jun 26, 2009 | 06:11 PM
vettenuts's Avatar
vettenuts
Since the hydraulic lifter will compress, I use the same method in the car, i.e., use check springs and a dial indicator.
Old Jun 26, 2009 | 09:08 PM
geezel's Avatar
geezel
What' everone's opinion on stock rockers with higher lift cams (0.585 / 0.585)?. That's the only reason I'm looking into the swap. Maybe not worthwhile?
Old Jun 27, 2009 | 09:51 AM
vettenuts's Avatar
vettenuts
Lots run them, not many bother to set them up. They should work well but you need to again verify the wipe pattern. Harder to set wipe due to shims not generally available. Very light rocker. Comp has a new trunnion kit for them.
To Roller Rocker Wipe Pattern
