fuel gage dropping to E!!!! help
Old Jun 30, 2009 | 07:50 PM
black*out*vette's Avatar
black*out*vette
Default fuel gage dropping to E!!!! help
hey everyone
this weekend my fuel gage just dropped to E and my check gages light stays on. anybody know what may cause this and how to fix it??
thanks
will
Old Jun 30, 2009 | 08:03 PM
VinnyT's Avatar
VinnyT
You have the dreaded fuel gauge sender problem. Caused by a build-up of crap on the sensor in the tank. Get a few bottles of Techron fuel system cleaner from you local auto parts store and dump in the gas tank. Make sure you are using premuim top-tier fuel. It should clear up within the tank of fuel.
Old Jun 30, 2009 | 08:07 PM
black*out*vette
ok great thank you! i always use 93 in it and i will go tomm and buy some of that stuff!
Old Jun 30, 2009 | 08:17 PM
timemender's Avatar
timemender
Get the Techron PLUS – best for sulfur deposits, which is most likely the cause.
Run a bottle through a couple of times per year to keep the fuel tank sensors clean.
It may take two or three (or four) tanks of fuel with the Techron PLUS added to repair the fuel gauge reading at this point in time.
Old Jun 30, 2009 | 08:20 PM
black*out*vette
is this a def fix, or could there possibly be something more that is wrong with it. soon im installing a racetronix fuel system, so i will find out one way or another!
thanks guys
Old Jun 30, 2009 | 08:25 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
If the problem occurs more at a certain drive time (for most 40 minutes) than a particular fuel level then it is probably a firmware problem.
Old Jun 30, 2009 | 08:29 PM
black*out*vette
well it happened saturday and is still the same way
Old Jun 30, 2009 | 08:53 PM
wfdlt8's Avatar
wfdlt8
What is the solution to the firmware problem?
Old Jun 30, 2009 | 08:58 PM
black*out*vette
i second that question!!
Old Jun 30, 2009 | 09:00 PM
Mark C5's Avatar
Mark C5
Go to this site and enter your vin. It will give you the firmware updates for your vehicle. Take them to the dealer and have them check to see if they're done and if not enter them.
http://tis2web.service.gm.com/tis2web
If you have a custom tune this is a problem as they will have to set everything back to stock. This is why I haven't tried it yet.
I don't have any personal experience this fix works but others have said it works. All I know is if your gauge drops after driving 40 minutes every time, all the Techron or Seafoam in the world won't fix it.
Old Jun 30, 2009 | 09:01 PM
black*out*vette
ok thanks, im thinking it is more than that, because it has stayed on E everytime i have turned the car on for the past 4 days!
Old Jun 30, 2009 | 09:03 PM
wfdlt8's Avatar
wfdlt8
What is the site? Link please.
Old Jun 30, 2009 | 09:05 PM
Mark C5's Avatar
Mark C5
Sorry, I forgot to add the link, it's there now.
Old Jun 30, 2009 | 09:06 PM
black*out*vette
thanks alot for your help!!
Old Jun 30, 2009 | 09:12 PM
Mark C5's Avatar
Mark C5
Glad to, hope it helps.
wfdlt8's Avatar
wfdlt8
Thanks.
Old Jul 1, 2009 | 01:11 AM
zwaldo's Avatar
zwaldo
I ran my tank down to almost bone dry because well, I kept putting it off. It never sputtered but I'm sure it was very close. the next time I filled my tank up and it got down to about 1/4 a tank of gas it suddenly dropped to nothing like yours did. I haven't had it do it since but i'll throw some tech in there.
Old Jul 1, 2009 | 05:33 AM
9secondflat's Avatar
9secondflat
been there done that bought the t shirt.....save your money on the additives...just "wiggle your ***" take the car on a less traveled road and at around 40-50 mph move the wheel hard left and hard right two times...this will fix your problem. its not a perminent fix but neither is the fuel additive and you just saved 7 bucks.
Old Jul 1, 2009 | 06:49 AM
holterhouse's Avatar
holterhouse
The dealer will charge you $1300.00 for the real fix.
To fuel gage dropping to E!!!! help
