New underdrive pulley!
Old Jul 1, 2009 | 07:44 PM
chrisbenoit's Avatar
chrisbenoit
Default New underdrive pulley!
I am going to order a underdrive pulley for my 99 FRC. I understand that the original isn't keyed or pinned. Is it necessary to pin or key the new balancer to the crank? I can assure you there will be not turbo or supercharger in my future. Just basic bolt-ons.
Old Jul 1, 2009 | 07:45 PM
vettenuts's Avatar
vettenuts
Not necessary but many do it as a precaution. I did when it was apart.
Old Jul 1, 2009 | 07:52 PM
chrisbenoit
Do most people pin perpendicular to the shaft like a key or install the balancer and then drill parallel to both the crank and balancer?
Old Jul 1, 2009 | 09:49 PM
DIXZ's Avatar
DIXZ
When I installed my PowerBond pulley I pinned it, for the piece of mind.
I sleep very well at night
Mine was perpendicular.
I have since removed the pulley and re-installed with no problem at all.
Old Jul 1, 2009 | 11:13 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Since the balancers are not keyed on, is there a wrong way to install the balancer?
The reason I ask is I just pressed my underdrive balancer on when I was building the LS motor for my 70 and let it be.
Old Jul 1, 2009 | 11:19 PM
lucky131969's Avatar
lucky131969
More important on a C5 (depending if it's an auto or manual), if a stock balancer is used, etc.
Old Jul 1, 2009 | 11:20 PM
lucky131969
No biggie. You can always pull it back apart and pin it if it comes loose....right?
99torchredlb's Avatar
99torchredlb
Best bet is to key it. My has slipped for the 3rd time.....
Old Jul 2, 2009 | 01:16 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The GM procedure for a MANUAL C5 is to mark the OEM damper orientation on the MANUAL Tranny crank and reinstall it in the same position. Remove the OEM damper balancing pins and position them in the NEW OEM damper. If you use an AFTERMARKET Damper,,,your on your own. I just installed my Powerbond damper and all was well!
I pinned mine for PIECE OF MIND and have NOT had any issues!
BC
Old Jul 2, 2009 | 08:10 AM
ArKay99's Avatar
ArKay99
Originally Posted by MckinleyC5
I read about the new pulley (HARMONIC BALANCER / UNDERDRIVE PULLEY for: LS1 / LS6 / LS2 / LS3) and its benefits. Does it really help with performance? Is there a wrong way to install it if you key it during installation? Is there anyone out there that might have some important information or insight about this new pulley or the installation involved? I found it in 2 different places, it looks like the cheapest place so far is Corvette Central @ $214.95
You might be better off if you started your own thread on this. You'll get more feedback and won't be accused of hijacking someone else's thread.
Old Jul 2, 2009 | 08:50 AM
MckinleyC5's Avatar
MckinleyC5
Cruising
Default Sorry....
Sorry about that, not trying to step on anyones toes....
To New underdrive pulley!
