driver side rearview mirror blurred
Old Jul 3, 2009 | 10:57 AM
boostedvette01's Avatar
boostedvette01
Default driver side rearview mirror blurred
I guess the chemical for the autodimming feature has leaked between the glass giving it a blurred look. Have any of you guys ran into this problem and know where to get the replacement other than GM. They quoted $420 just for the glass. Also how do i get the old glass out without breaking the whole assembly. Any help would be appreciated.
Old Jul 3, 2009 | 11:04 AM
boostedvette01
sorry just looked below and seen a thread just like mine. If an admin reads this please close this this thread
Old Jul 3, 2009 | 11:09 AM
TEXHAWK0's Avatar
TEXHAWK0
Everything in my mirrors are always blurred too! Imagine that.
Old Jul 4, 2009 | 03:32 AM
DeeGee's Avatar
DeeGee
Here's the procedure
Try GMpartshouse.com for a better price if you want new. At that price, I'd be tempted to look for a used mirror from one of the breakers. There are some vendors on the Forum who sell used parts. The links are in the icons on the left.
Document ID# 657162
2002 Chevrolet Corvette
Mirror Face Replacement
Removal Procedure
Caution
When working with any type of glass or sheet metal with exposed or rough edges, wear approved safety glasses and gloves in order to reduce the chance of personal injury.
1. Push in on 1 edge of the mirror face glass tilting the mirror case to allow finger access.
2. Grasp the glass case firmly and pull the case from the mirror body.
3. Disconnect the wire connectors from the case (heated mirror).
4. Remove the 2 jackscrews from the mirror glass case.
1. Bend the jackscrew over.
2. Press down on the side of the jackscrew popping the jackscrew from the mirror glass case.
3. Save the jackscrews for reinstallation to the mirror motor.
Installation Procedure
Caution
IMPORTANT
The mirror glass case is not the same for the right and left mirror. For ease of assembly of the mirror glass case place a little white lithium grease on the motor pivot and on the tip of the installed jackscrews.
1. The jackscrew springs must be positioned down compressing the fingers at the bottom of the jackscrews.
Push to install the jackscrews into the mirror motor.
Object Number: 167812 Size: SH
Click here for detailed picture of above image.
2. Rotate both jackscrews to position the ball flanges to be inline with the attaching hub. They will then be correctly positioned to the mirror glass case. (This is shown in the above graphic).
3. Connect the electrical connectors to the mirror glass case (heated mirror).
4. Align the case to the mirror motor.
5. With the palm of your gloved hand press firmly on the center of the mirror glass case until the case engages onto the motor.
6. Push the mirror glass case to the jackscrews.
* Right mirror. Rotate the mirror glass case down and press firmly on the lower side engaging the mirror glass case to the lower jackscrew.
* Left mirror. Rotate the mirror glass case up and press firmly on the upper side engaging the mirror glass case to the upper jackscrew.
* Rotate the mirror glass case and press firmly on the outer side engaging the mirror glass case to the outer jackscrew. The jackscrews will give a clicking noise when properly seated.
Document ID# 657162
Old Jul 5, 2009 | 11:01 PM
boostedvette01
Thanks that was very helpful post
To driver side rearview mirror blurred
