Sway Bar Bushing - $180 to Install???
Old Jul 8, 2009 | 09:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by timemender
2 hours to get it on the lift, Plus 10-minutes for coffee & donuts, Plus 15 minutes to install, Plus 5-minutes to remove from service bay, = 2-1/2 hours.
What's the problem.
I'm surprised they didn't add in a potty break what with all the coffee & donuts.
DAMN IT,,,, You forgot to add the shop rag and hazardous waste disposal fee. I had a dealer program my BCM a long time ago and that that on there. I about lost it. They took it off after I bitched..
The economy makes people get creative..
BC
Old Jul 10, 2009 | 04:05 AM
Jesse Asis's Avatar
Jesse Asis
Easy .... Front : Jack up vehicle, un-bolt the sway bar bushing clamps, remove old bushing, install new bushing, lub it with white grease (Bushing has cut so they spread and clamp over Sway Bar). Re-install, re-bolt about 90lbs torque.
Rear : Same as front, you will see after doing it.
You don't need to remove the sway bar, best jack car up with two jack stands and the jack lift in the center assisting holding the vehicle. Best is to but wheel box under tires. Good luck.
Old Jul 10, 2009 | 03:06 PM
kg54trains's Avatar
kg54trains
Originally Posted by dpilko
Hello,
I've got the typical corvette-creaking noise, and am going to buy the Zip corvette aftermarket bushings, front and rear.
What is a fair price to have them installed? The dealership wants $180, and a corvette specialty shop wants $100.
I have virtually no experience working on cars, but is this simple to do? Do you have to remove the tires and the sway bars?
Thanks in advance,
Dave
While your are there think about the replacement of the Sway bars front and rear. Costs have dropped and it adds about a hour to the job.
Old Jul 10, 2009 | 09:10 PM
jrprich's Avatar
jrprich
Originally Posted by Jesse Asis
Easy ....
Re-install, re-bolt about 90lbs torque..
Actually 90 lbs is too much.....you could break a bolt
Front
43 lb ft
Rear:
lower 70 lb ft
upper 49 lb ft
Old Nov 24, 2009 | 10:45 AM
TC101's Avatar
TC101
Great thread I am doing this today to get rid of that dreaded old creaky staircase noise! I thought it was from removing the front bolts when I lowered the car, so I put new C6 style bolts back in and it still made the creak noise, so I have brand new OEM bushings coming today and Id like to install! Thanks for the info!
Old Nov 26, 2009 | 02:42 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
What's the problem.
You forgot something. It's 5 minutes to get it on the lift. 15 minutes at the parts counter waiting on the parts. 5 minutes for the front, 5 for the rear. It's a $20. deal. What you all forgot was the 90 minute test drive on your dime. Then they will try to sell you new tires as your car sits there with smoking rear tires.
For $180. I got ZO6 bars and bushings from Gene and installed them in about a half hour. One of the more simpler DIY jobs you can do.
Old Nov 26, 2009 | 09:31 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Thats for sure! Man, I have a whole long list of horror stories from my car going to the dealership. Change the bushings yourself and you will be happy you did.
Old Nov 26, 2009 | 09:55 AM
K RIPPER's Avatar
K RIPPER
HEY VETTENUTS GREAT IDEA FOR TEFLON TAPE!!!! YOU TAUGHT AN OLD DOG A NEW TRICK ...THANKS!!!! The forum is your friend 'nuff said
Old Nov 26, 2009 | 12:19 PM
minitech's Avatar
minitech
Anyone have the actual GM dealership book where it tells the hour time for this job?
Old Apr 23, 2010 | 05:50 PM
Tony B's Avatar
Tony B
Default Bushings
Thanks to everybody! Ordered the parts and will do it myself!
Did you do it yourself...I have the same problem...what parts did you order and was it easy.....HELP!!!!!
Old Apr 23, 2010 | 06:00 PM
81c3's Avatar
81c3
I bought PFADT poly bushings. $42. shipped.
Old Apr 23, 2010 | 07:13 PM
Solofast's Avatar
Solofast
You guys forgot the part where when you hand the keys to the service manager he kisses you...
That way you will feel more comfortable..
You are probably used to getting kissed just before you get screwed....
Old Apr 25, 2010 | 01:50 AM
  #33
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
I see I already posted to this thread but as I was reading thoughts like yours came to mind, well kinda. I was leaning towards the lube as astro glide and a reach around for $180.
