Sway Bar Bushing - $180 to Install???
Old Jul 6, 2009 | 05:50 PM
dpilko's Avatar
dpilko
3rd Gear
Default Sway Bar Bushing - $180 to Install???
Hello,
I've got the typical corvette-creaking noise, and am going to buy the Zip corvette aftermarket bushings, front and rear.
What is a fair price to have them installed? The dealership wants $180, and a corvette specialty shop wants $100.
I have virtually no experience working on cars, but is this simple to do? Do you have to remove the tires and the sway bars?
Thanks in advance,
Dave
Old Jul 6, 2009 | 06:02 PM
Its_Go_Time's Avatar
Its_Go_Time
Originally Posted by dpilko
Hello,
Thanks in advance,
Dave
It doesnt really get any simpler. You dont even need to take the tires off if you have ramps. Just remove the screws/nuts holding the bushing brackets to the crossmembers, pull the bar away from the car, spread the old bushing off and slip the new on. lube up the bar if ur using poly bushings. Wouldnt spend $180 on that.
Old Jul 6, 2009 | 06:12 PM
randy814u's Avatar
randy814u
Do it yourself. It is easier then mowing the lawn.
Old Jul 6, 2009 | 06:21 PM
vettenuts's Avatar
vettenuts
One other thing if you want to try it. I didn't use lubricant on mine I used Teflon tape (plumbing tape) on the bar under the bushing. Several wraps and then install the bushing. No noise.
Old Jul 6, 2009 | 06:48 PM
Its_Go_Time
You mentioned this before. It sounds like a pretty good idea! grease tends to wash away after a while, though I can still go a whole season without them squeaking. My control arm bushings are another matter
Old Jul 6, 2009 | 06:53 PM
SUNNYD 95's Avatar
SUNNYD 95
Hello,
Thanks in advance,
Dave
Hey Dave, bring it over to my house I'll put all 4 of them on for 50 bucks.
Old Jul 6, 2009 | 06:55 PM
randy814u's Avatar
randy814u
You should do it for the cost of a beer, or just to help someone out.
Old Jul 6, 2009 | 07:51 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
you can easily do it yourself.
Old Jul 6, 2009 | 08:14 PM
MagRedConv's Avatar
MagRedConv
Ask the dealership to give full detail into what they need to do to install them. $180 = around 2 1/2 hours labor; it should be a good story.
Old Jul 6, 2009 | 09:37 PM
Fast Cop's Avatar
Fast Cop
DIY job. Go for it!!!!!
Old Jul 6, 2009 | 09:54 PM
Wicked Weasel
2 hours to get it on the lift
Old Jul 6, 2009 | 11:23 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Where are you located? If you're local to Metro Detroit, buy me lunch and we'll call it even!
Old Jul 7, 2009 | 01:35 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
It takes like 5 minutes per bushing if even that once you are under it. The rears, you don't even need to jack it up. Fronts you do of course but even so, its fast and simple
Old Jul 8, 2009 | 10:38 AM
dpilko's Avatar
dpilko
3rd Gear
Excellent! Thanks guys.
Is there an online "how-to" that shows pictures/directions of what I'm looking for once I get the car on jacks? I'm sure it's extremely obvious once you know what you're looking for (the long bar...), but I don't
Dave
Old Jul 8, 2009 | 11:12 AM
nickolbag's Avatar
nickolbag
$180 to install sway bar bushings?!?!?! Man I'm in the wrong business. If you were local to me I'd tell you to come over and I'd help you do it for free.
Old Jul 8, 2009 | 11:15 AM
kasper-pA-'s Avatar
kasper-pA-
St. Jude Donor '05, '14, '15
Dave
Here's ls1howto.com's sway removal and install guide, has pics on the bushings, should help you out!
http://www.ls1howto.com/index.php?article=16
Kasp
Old Jul 8, 2009 | 11:55 AM
dgrant3830's Avatar
dgrant3830
Get under there and see for yourself... they are real obvious and real easy.
To Sway Bar Bushing - $180 to Install???
Old Jul 8, 2009 | 12:31 PM
dpilko's Avatar
dpilko
3rd Gear
Thanks to everybody! Ordered the parts and will do it myself!
Old Jul 8, 2009 | 02:59 PM
dgrant3830's Avatar
dgrant3830
You might check with a Moderator and find out if its Ok to post the name of the offending dealership so anyone in your local area will know to avoid this dealership.
Old Jul 8, 2009 | 07:35 PM
timemender's Avatar
timemender
2 hours to get it on the lift, Plus 10-minutes for coffee & donuts, Plus 15 minutes to install, Plus 5-minutes to remove from service bay, = 2-1/2 hours.
What's the problem.
I'm surprised they didn't add in a potty break what with all the coffee & donuts.
