Stability Control messing up
Old Jul 6, 2009 | 06:44 PM
ff_jeff's Avatar
ff_jeff
Default Stability Control messing up
Hi, I have a 2004 corvette A4 with just an intake. Ever since we bought the thing about 6-7 months ago, every once in a while the stability management will mess up and turn off while driving normal. Sometimes the car will kinda jerk to the left a foot or two. When it does this it will also turn off cruise control. The check gauges will appear on the HUD and the service stability management will show up. I can turn off the car, or reset the code and it will be gone for sometimes a few weeks.
lately it does it more and more.
Help!!!!
Old Jul 6, 2009 | 07:53 PM
timemender's Avatar
timemender
Pull the codes (through the DIC). I would first clear all the codes and see which ones come back.
Post your findings (codes) here in "C5 Tech" for additional help.
Old Jul 6, 2009 | 11:51 PM
ff_jeff's Avatar
ff_jeff
ok I had some tcs codes and wrote them down before I cleared them. They didnt come back when I cleared them, but the postit i wrote them on flew out the window.
here are the remaining codes.
-SCM-
B2177 H C
B2860 H C
-HVAC-
B0333
B0361
B0441
I dont think these are causing the stability management to activate on its own for no reason, But Im no expert.
BTW it did it again while test driving the car. But no codes. Just said active stability, or something like that for a second on the screen. When it does this I think it makes the car brake on the front left tire because the cruise cuts off, and the car will yaw to the left.
Old Jul 7, 2009 | 12:28 PM
ff_jeff's Avatar
ff_jeff
Originally Posted by ff_jeff
ok i had some tcs codes and wrote them down before i cleared them. They didnt come back when i cleared them, but the postit i wrote them on flew out the window.
Here are the remaining codes.
-scm-
b2177 h c
b2860 h c
-hvac-
b0333
b0361
b0441
i dont think these are causing the stability management to activate on its own for no reason, but im no expert.
Btw it did it again while test driving the car. But no codes. Just said active stability, or something like that for a second on the screen. When it does this i think it makes the car brake on the front left tire because the cruise cuts off, and the car will yaw to the left.
bump
Old Jul 7, 2009 | 02:11 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
bump
B2177 Seat Front Down Switch Shorted to GND
DTC B2860 Telescoping Column Position Sensor Failure
Second one would seem to be the cause of your active handling kicking in.
Old Jul 7, 2009 | 03:49 PM
AU N EGL's Avatar
AU N EGL
did not the 04s have a recall on this?
our 04 A4 had this problem. Need to replace the yaw sensor
Old Jul 8, 2009 | 12:25 AM
ff_jeff's Avatar
ff_jeff
How would I find out if it was recalled? Go to a dealership?
Thanx for all the help BTW.
Old Jul 8, 2009 | 01:26 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You either have a bad Steering Wheel Position Sensor (SWAPS), a bad YAW sensor or the EBTCM is failing and giving out bad commands.
BC
Old Jul 10, 2009 | 06:41 AM
ff_jeff's Avatar
ff_jeff
So how do I fix this?
Old Jul 10, 2009 | 08:13 AM
AU N EGL's Avatar
AU N EGL
tech II or take the car to a dealer
To Stability Control messing up
