Throttle body coolent by-pass
Old Jul 17, 2009 | 10:15 AM
Jims79's Avatar
Jims79
Default Throttle body coolent by-pass
Have any of you disconnected the coolent by-pass from the throttle body? Is it worth the trouble? I read that the by-pass will keep the incomming air cooler. If I put in a by-pass do I need to block the open ports on the throttle body?
Old Jul 17, 2009 | 10:30 AM
Gideon's_Test's Avatar
Gideon's_Test
I did it. Didn't notice any difference whatsoever (didn't expect to, really). It does cool the air a bit...I didn't cap the the coolant pipes on the TB till long after I did the mod. I went to Autozone, and they sell a package of rubber/vinyl caps...
If I drove the vette in freezing or near freezing temps, I probably wouldn't have bothered doing it...
Old Jul 17, 2009 | 10:31 AM
lucky131969's Avatar
lucky131969
Don't waste your time...
Old Jul 17, 2009 | 10:41 AM
Jims79's Avatar
Jims79
Thanks guys....
Old Jul 17, 2009 | 11:55 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I did it too on both my C5s. The C6 TB does NOT have coolant flowing thru it. I guess GM figured out that they really dont need it.
Old Jul 17, 2009 | 11:57 AM
redrckt97's Avatar
redrckt97
yes, no, no.
Old Jul 17, 2009 | 04:07 PM
1Sweet66's Avatar
1Sweet66
I guess I'm in good company. Did it on my '99. Figured that since I live in the south and rarely see temps below 30 degrees it couldn't hurt.
Interesting to see they eliminated it on the C6.
Old Jul 17, 2009 | 08:07 PM
Last C5's Avatar
Last C5
I did it on both my vert and Z so it would be easier to work on the manifolds or TBs when I wanted to.
Old Jul 17, 2009 | 09:52 PM
JCamaro's Avatar
JCamaro
Just do it. Does it give you more hp? No... but do it anyways.
Old Jul 17, 2009 | 09:56 PM
C5XTASY's Avatar
C5XTASY
Just ask yourself how long air spends in the throttle body. It's a fraction of a second....not long enough to pick up any heat. Coolant is run through the throttle body to ensure the blade doesn't freeze in extreme cold. This mod is of zero value except to the stores that sell you the parts to do it.
Ed
To Throttle body coolent by-pass
