elect. problems
Old Jul 18, 2009 | 09:04 AM
SPARTANMECH's Avatar
SPARTANMECH
5th Gear
Default elect. problems
:My 2000 seem to have a mind of its own. The dash goes crazy, pass. window wont go down , traction control lights up, reduce engine power just to list a few. I have went threw ever ground in the car now and Im still having the same problems. They come and go like the wind.
Old Jul 18, 2009 | 09:13 AM
NavyDoc2007's Avatar
NavyDoc2007
Here ya go.
http://forums.corvetteforum.com/c5-t...-gremlins.html
Old Jul 18, 2009 | 09:21 AM
SPARTANMECH
5th Gear
thanks i will give it a try . Wish me luck .
Old Jul 18, 2009 | 09:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If your BCm and carpet underlayment isnt wet, you ave door wiring harness connector issues!
Let us know how you make out.
BC
Old Jul 18, 2009 | 10:29 PM
BigGun's Avatar
BigGun
BC
If you can"t find the problem, post the dic codes.
Sure sounds like the door harness.
Old Jul 19, 2009 | 12:57 PM
NavyDoc2007
Any updates?
Old Jul 20, 2009 | 01:46 PM
SPARTANMECH
5th Gear
Looks like the door wire was the problem. thanks to all
Old Jul 20, 2009 | 01:49 PM
lucky131969's Avatar
lucky131969
what did you find/fix?
Old Jul 20, 2009 | 01:51 PM
SPARTANMECH
5th Gear
loose wire in the wiring harness.
Old Jul 20, 2009 | 01:53 PM
lucky131969
Old Jul 20, 2009 | 05:24 PM
SPARTANMECH
5th Gear
Looks like the problem has come back. im back to square 1.
Old Jul 20, 2009 | 11:20 PM
NavyDoc2007
Did you check both door harnesses?
Are there any codes coming up? Check for codes by holding down the 'options' button and pressing the 'fuel' button 4 times.
To elect. problems
