High Temp Caliper Paint Question....
Old Jul 18, 2009 | 03:32 PM
C5Ken's Avatar
C5Ken
Default High Temp Caliper Paint Question....
I need to paint the calipers on my C5. Should I use Foliatec paint or is there some other product that I can use. Also, can you tell me where to purchase the paint you recommend. Thanks for your help.
Old Jul 18, 2009 | 03:38 PM
chuffo302stang's Avatar
chuffo302stang
Default I used duplicolor BLACK
i used duplicolor black turned out pretty good. Picked it up at autozone.
Old Jul 18, 2009 | 03:49 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Rustoleum from Lowes covered with clear engine enamel from Auto Zone
Old Jul 18, 2009 | 05:14 PM
Indy's Avatar
Indy
Rustoleum usually works fine
Old Jul 18, 2009 | 05:19 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
rustoleum Sunrise Red is closest to Torch Red, if that's what you have. it will fade a bit over the years, but it's easy to touch up because you are not spraying it on, which requires tedious masking. only drawback is it is slooooooooooow drying...overnight is best.
Old Jul 18, 2009 | 05:48 PM
rockinvette's Avatar
rockinvette
I used Dupli-color. Be careful they dry quick but turn out great. http://images.ibsrv.net/ibsrv/res/sr...s/thumbsup.gif
Old Jul 18, 2009 | 06:07 PM
rebelheart's Avatar
rebelheart
Dupli-color from autozone....16 bucks. Just get some thinner to get a smoother finish!
Old Jul 18, 2009 | 06:34 PM
C5Ken's Avatar
C5Ken
Thanks for all of the info.....
Old Jul 18, 2009 | 10:55 PM
Secret237's Avatar
Secret237
VHT makes a "Caliper paint" So it's a higher temp paint, I think 900 degrees.
But they also make a clear coat, so, take your calipers off, paint them RED, sand off the letters "CORVETE" then Clear coat them.
Paint the brackets Black
Good luck
Old Jul 19, 2009 | 12:29 AM
jrose7004's Avatar
jrose7004
I used VHT brand from a rattle can.
Old Jul 19, 2009 | 09:02 AM
Secret237's Avatar
Secret237
Yes, VHT from a rattle can
To High Temp Caliper Paint Question....
