Catch Can for PCV
Old Jul 18, 2009 | 10:56 PM
intoc6s's Avatar
intoc6s
Default Catch Can for PCV
For a Naturally Aspirated engine, should my Catch can have 2 ports or 1? I bought a Catch Can about a yr ago from my dyno-tuner and he installed it. I have always noticed that it has only one port.(its at the top) There s no hoses between the intake or the Throttle body and the Can either. Just hoses from the valve covers to the CatchCan. I feel like it needs another port on the Can with a hose connected to engine vacuum. Am I right? (My car is a 2001- fwiw)
Old Jul 19, 2009 | 04:03 AM
dieseldave56's Avatar
dieseldave56
Default closed loop emissions
The positive crankcase ventilaltion (PCV) is a closed loop system. The oil catch can is installed after the PCV valve (#1 port) and the line continues from the second (#2 port) lower port to the intake manifold, throttle body, ect This for the emissions minded person.
All that you want is to incorporate the oil catch can into the closed loop system. Most here have to deal with emissions . http://eliteengineeringusa.com/Insta...uctions_CC.pdf
The oil catch you have must be vented to atmosphere. This is more performance oriented as the oil foul crankcase vapors displace the air /fuel mixture. The more blow-by the more air/fuel mixture is displaced.
In either case use the largest diameter hoses possible to help slow the oil vapors down and collect in the can.
Old Jul 19, 2009 | 04:42 AM
intoc6s's Avatar
intoc6s
Thanks Dave! As a matter of fact Mine is vented! And it rarely gets anything in it..besides condensation when the weather is COLD! I will no longer worry about it! - Jason
Old Jul 19, 2009 | 08:46 AM
hawk4077's Avatar
hawk4077
I don't understand how your can could be working right with only one line on it to remove vapors from crankcase you need a second vacum line of the manifold thats why you don't get any oil in it. nothing is being drawn into it.
Old Jul 19, 2009 | 03:14 PM
intoc6s's Avatar
intoc6s
That was my concern. Without 2 ports, one for engine vacuum, it seems like nothing would get pulled into the can.
Old Jul 19, 2009 | 05:06 PM
hawk4077's Avatar
hawk4077
I have one from elite eng. on my 02 coupe has two lines one from pcv valve and one going to side of manifold and it works I do find oil in it ever oil change not much but at least it's not in the manifold.
Old Jul 19, 2009 | 05:15 PM
intoc6s's Avatar
intoc6s
Im getting one with 2 ports- or modding mine for 2 ports, then! I looked in my intake, behind the TB and there s a small amount of oil...And i Paid a Sh!tTon for that one i have! That s what i get for going to the tuner(or anywhere that has Vette parts) with a fistfull of dollars! lol
One question- Does the line run into the intake or in front of the TB?(the vacuum for the cannister)
Old Jul 19, 2009 | 07:09 PM
Dave68's Avatar
Dave68
Take a look at my procedure for installing a catch can (where I think it should be installed) in an 01 C5. It is entitled: "How to install a CP catch can in a C5 Corvette (NEW)" There are plenty of pictures that show you where the intake hookup is.
Also on this page is a paper on PCV valves and a bunch of other relevant stuff.
http://www.conceptualpolymer.com/corvette_c5_corner.htm
Dave
Old Jul 20, 2009 | 03:07 AM
dieseldave56
Default crankcase pressure
Engine reciprocating parts in the engine and whatever blow-by created pressure in the crankcase. Blow-by being the symptom* of the high volume of moisture /oil fouled air and the LS1s and LS6es ventilation system inability to seperate both at high engine speeds and MAP that generated the high oil consumption . Try sealing off your crankcase , valve cover vents and watch what happens.
Obviously the most accepted way is to draw oil fouled air and blow-by out of the crankcase is with manifold vacuum, the combination of piston action and fresh air . But the cost is in decreased performance , ect. as the fouled air displaces air/fuel mixture , inundates the intake manifold, combustion chamber, ect. which is why the importance of an efficient oil catch can . That includes fouled air circulation, condensation ( GM engineers call this the "rain drop analysis") thru design and installation.
* read my posts on the causes of high oil consumption of the LS1 and LS6 http://forums.corvetteforum.com/c5-t...post1570223936
To Catch Can for PCV
