lug nuts
Old Jul 19, 2009 | 11:44 AM
Slogo's Avatar
Slogo
Default lug nuts
What is correct torque for stock wheel lug nuts. Last guy didn't use torque wrench and needed breaker bar to remove one wheel.(warped rotor) too
Old Jul 19, 2009 | 11:48 AM
byronhunter's Avatar
byronhunter
100 Lbs/Ft.
Old Jul 19, 2009 | 09:20 PM
Indy's Avatar
Indy
Old Jul 19, 2009 | 10:41 PM
Bill Dearborn's Avatar
Bill Dearborn
Despite comments otherwise it is hard to believe the rotor warped from the lug nuts being overtorqued. Cars using sealed bearing hubs squeeze the center of the rotor between the hub flange and the wheel. This doesn't do anything to pull the rotor surface in any direction. With cars using a spindle with the bearing and lug bolts mounted in the rotor it might be possible to warp a rotor that is overtorqued.
Bill
Old Jul 20, 2009 | 01:01 AM
Its_Go_Time's Avatar
Its_Go_Time
Bill
100%
Old Jul 20, 2009 | 02:25 AM
c5blkvetteguy's Avatar
c5blkvetteguy
The owners manual says to torque to 25, then 50, then 75, then to 100 ft lbs. It seems overkill to me, but I do it.
Old Jul 20, 2009 | 06:19 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I torque to 100 and then recheck when done. I check every other month for the street. At the track I check 10x per day.
Old Jul 20, 2009 | 07:29 AM
AU N EGL's Avatar
AU N EGL
I think that is over kill also. I use a impact gun which takes the lug nuts to about 75-80 lb-ft, then I torque to 100 lb- ft
Old Jul 20, 2009 | 10:48 AM
jovette's Avatar
jovette
I torque to 75, then to 100, just two steps for me
Old Jul 20, 2009 | 12:15 PM
hotwheels57's Avatar
hotwheels57
Where's the guy who regularly used to argue that 90# was just fine in his opinion?
He's probably still looking for his wheel...
To lug nuts
