"as cast heads"
Old Jul 20, 2009 | 08:22 AM
dadsturn's Avatar
dadsturn
St. Jude Donor '08-'09
Default "as cast heads"
has anyone besides Vengence applied these heads? Any thoughts from those that have? Hp/torq. increases, performance, seat of the pants?
TF has stated to me a gain of 40-60 hp. over stock heads. They will be replacing old MTI (Houston) 2e heads that gave me nothing.
Old Jul 20, 2009 | 11:04 AM
SDLS1Rider's Avatar
SDLS1Rider
I have been doing a lot of searches on the subject of heads lately. I think we need more information.
Who's cast heads are they? What is the source company and who do you plan on doing the CNC?
Old Jul 20, 2009 | 11:09 AM
AU N EGL's Avatar
AU N EGL
as cast usually means ready to be ported.
Old Jul 20, 2009 | 01:56 PM
dadsturn's Avatar
dadsturn
Trickflow has created a 220 head that was designed with the porting that was accomplished on there CNC 215 heads. It is a ported head without the polishing. HP figures are 40-60hp over stock heads.
Old Jul 21, 2009 | 07:49 AM
dadsturn's Avatar
dadsturn
ttt
anybody???????????
Old Dec 8, 2009 | 08:18 PM
RayMiller's Avatar
RayMiller
ttt
Old Dec 9, 2009 | 09:51 PM
94brick's Avatar
94brick
bump for more info on heads giving 40-60 more hp
Old Jan 2, 2010 | 03:55 PM
REDZED2's Avatar
REDZED2
The TFS "as cast" heads are fully CNC'd in the chambers, just have a rough cast runner. Ron at Vengence says there is an 8-10 hp diff between these and the CNC 215's.. also they are 700 bucks less.
Old Jan 7, 2010 | 11:16 PM
AntonioZ06's Avatar
AntonioZ06
so just almost the same but not polished in the runner? Couldn't it just be polished then?
Old Jan 7, 2010 | 11:37 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
They could be...but you'll probably hurt more than help. No one polishes the runners.
Look at any GOOD cnc'd head, and note the tool marks and surface roughness in the runners...they are purposely left there for a reason.
That desired surface finish (roughness) can easily be achieved in casting, but it's only advantageous IF you can nail the port dimensions right in the casting process. (As opposed to others, who purposely cast heads with extra material added, only to machine out to the finished dimensions).
So it's not that one is finished, and the other isn't...it's two different methods of achieving the finished product.
That is why "as cast" are so much cheaper, it eliminates a lot of machine time and labor to manufacture the finished product.
Old Jan 7, 2010 | 11:53 PM
mathia's Avatar
mathia
There's a thread on ls1tech that covers this:
http://www.ls1tech.com/forums/dynamo...ds-please.html
See posts 20 and 24.
To "as cast heads"
