Lets play name that part (w/Pics)!
Me holding the Item I can't yet identify.
http://forums.corvetteforum.com/c5-t...e-picture.html
Since I could get the hose off from the manifold I started chasing the hose back through the harness. I ended up having to cut a lot of it harness protector as the hose was pretty much worthless. Every time I touched it, it would break. The line had holes and cracks all the way through.
I just barely installed the new BCM I got. Hooked it up and now i've got the service column lock. I found a post about how to reset the BCM so you could drive it to dealership but I can't seem to find it. Anyone know if I need to have this reprogrammed? Maybe I just need to install a CLB.
Heres the stock vacuum fittings. The rubber 90 deg fitting is the vacuum line you looking for:
THEN,,,,,,,,,,it runs thru the factory wiring harnesses with the wires and goes here " the passenger fender ":
Your car most likely had a bad acid spill that damaged the vacuum line. Is that acid damage still apparent?????????????
If so, you MUST deal with that before you go any further!
BC
30 Minute Learn Procedure
1-Turn ON the ignition, with the engine OFF.
2-Attempt to start the engine, then release the key to ON (vehicle will not start).
3-Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
4-Turn OFF the ignition, and wait 5 seconds.
5-Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes (the vehicle is now ready to relearn the password on the next ignition switch transition from OFF to CRANK).
Important
The vehicle learns the password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6-Start the engine (the vehicle has now learned the password).
7-With a scan tool, clear any DTCs if needed (history DTCs will self clear after 100 ignition cycles).
byronhunter does his part too!
He provides EXCELLENT information and facts!Bill
I reprogrammed the BCM using the technique described and got the car at least started. Looks like I need to take it over to the dealership to have it fully reprogrammed to fix some minor issues. The BCM I picked up had automatic headlights as an option so mine turn on every time I start my car.
The reprogramming I did looks like didn't fix my column lock though. I'm getting the dreaded fuel cut after 2mph now. How is the BCM and column lock related? What I am wondering if I take it to the dealer to have the BCM reprogrammed will it take care of the column lock issue? If not, what would be the best way to take care of the column lock? From what I was reading, it seems I have to take it to the dealer. I've got the 6spd and I can't get the column lock to turn off at all. Should I or can I fix issue before I take it into the dealer for this issue?
