Questions
Old Jul 31, 2009 | 02:04 PM
gremmit's Avatar
gremmit
Default Questions
I have a few questions I hope someone may be able to answer. I have a 99 FRC. What size torque tube bushings does that use, the 10mm or the 12mm?
When replacing the left side output shaft, does the differential have to be removed to do that?
What is the fluid capacity of the clutch, how much fluid does it hold?
Sorry for the stupid questions. Thanks in advance for any help you can give.
Old Jul 31, 2009 | 02:43 PM
MattB's Avatar
MattB
I'm pretty sure they went to the 12mm in 01. And, I'd think it would be difficult to do the output shaft in place, I would think it would be quicker to just remove the diff. Do some searches, there is a writeup around here somewhere.
The clutch itself does not hold a lot, maybe an ounce. Are you looking to bleed it? If your going to drop the drive line, I'd look at getting a remote clutch bleeder. Its a LOT of work to get to the stock bleed screw.
