f45 shock troubles
Old Aug 2, 2009 | 07:12 PM
nvygw171's Avatar
nvygw171
Default f45 shock troubles
Would all 4 go out at once just sitting in my garage?
Fired up the vette today for the first time in about 3 months and now have a intermittent service active handling message and abs light. The suspension is now really stiff. I'm not sure if its all 4 because i think the back shocks are the ones i would feel while driving but the car is significantly lower in the back than it was.
Could this be from me reinstalling the t1 sway bars while it sat. I jacked up the back of the car to do it, was i not supposed to?
Old Aug 2, 2009 | 07:17 PM
jedblanks's Avatar
jedblanks
Did you unplug something and forget to plug it back in?
Old Aug 2, 2009 | 07:22 PM
Bill Dearborn's Avatar
Bill Dearborn
Active handling has nothing to do with the F45 shocks. Active Handling is part of the ABS system. The F45 shocks are part of the Real Time Damping system. Use the DIC to see what codes you have.
Bill
Old Aug 2, 2009 | 09:47 PM
nvygw171's Avatar
nvygw171
So i traced the active handling/abs lights back to another electrical so i cleared all the codes and went for a drive through the ortega came back and i have no codes what so ever, so that prob is fixed! Now what to do about rear shocks? when they go out do they go out in pairs? I actually liked the f45 shocks but do not like how expensive the replacements are.
Old Aug 3, 2009 | 12:07 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You will like the F45 until you experience a REAL performance suspension!
I hated my 98 F-45 crap! I sold it and purchased an 02 ZO6. Thats a performance suspension!!!!!!!!!!
Replace your F-45 crap with:
C6 ZO6 Shocks
C5 ZO6 Springs
C5 ZO6 or C6 ZO6 sway bars
You will be glad you did!
Ditch the F-45 crap and pick a real suspension designed to handle.
BC
BC
Old Aug 3, 2009 | 05:39 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I removed my F45 shocks, and installed Pfadt Coilovers. They are so much more superior!
http://forums.corvetteforum.com/c5-t...-new-post.html
Old Aug 3, 2009 | 11:50 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
To answer your question,,,NO,,not normaly. Read and post your DTCs. Theres most likely a common electrical issue. It could even be a FUSE issue. Post those DTCs!
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Aug 3, 2009 | 10:38 PM
nvygw171's Avatar
nvygw171
Thanks for the advice. Apon further inspection I noticed the rear leaf is cracked on Botha sides after the perches. That should def cause a rough ride!!! I'm going to replace front and rear leafs!
Old Aug 3, 2009 | 10:45 PM
ljthe2nd's Avatar
ljthe2nd
Instead of replacing the front and rear springs, now would be a good time to ditch the F-45 shocks and stock springs and go with some Pfadt coilovers.
To f45 shock troubles
