differential
Old Aug 3, 2009 | 03:59 PM
makn hp's Avatar
makn hp
Default differential
I have a 04 A4 vert it has a 273 rear gear will this change out with a342 without doing anything else.(the hole differential )
Old Aug 3, 2009 | 05:03 PM
corvette8189's Avatar
corvette8189
i dont know the answer to your queston but i have some 3.42 gears for sale.
i think you need a 3 rib case and i believe with 2.73 you have 2 rib but not sure
Old Aug 3, 2009 | 06:32 PM
vettezeke's Avatar
vettezeke
Default Going from 2.73 to 3.42
Every thing will bolt right in, but you will have to have your transmission shift points reset and the gear change set up in the computer. If you don't you will get a code P1870 ( transmission slip ) because the computer checks engine and output shaft speed when you are in 4th gear and the converter is locked. It will be thinking that the engine should be spinning slower cause it is programed for a 2.73. It interpets the extra engine speed as torque converter slip and sets the code P1870. Then the shifts get real ugly. It also inhibits the torque converter from locking again.You have to reprogram, I did mine with a Predater.
Old Aug 3, 2009 | 07:07 PM
Patches's Avatar
Patches
Same answers as in this thread.
http://forums.corvetteforum.com/c5-t...th-2-73-a.html
Old Aug 3, 2009 | 08:23 PM
makn hp's Avatar
makn hp
Default rear end
Corvette 8189, I don't need gears I have the hole thing I just need to know if it will fit without a problem
Old Aug 3, 2009 | 08:29 PM
Patches's Avatar
Patches
No problem - but read the thread I linked to anyway.
Old Aug 4, 2009 | 11:02 AM
makn hp's Avatar
makn hp
Default rear end
Patches, thanks 4 the help I needed it.
Old Aug 4, 2009 | 11:47 AM
NeutronVette's Avatar
NeutronVette
Let us know how the hole install goes.
Old Aug 4, 2009 | 12:45 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Me too...that was my initial thread that Patches quoted for you to read...best to be completely prepared.
Old Aug 4, 2009 | 05:57 PM
makn hp's Avatar
makn hp
Default rear end
Thanks 2 all that helped its nice 2 know there is a place I can go unlike a few other vinders I have gone 2
Old Aug 4, 2009 | 07:32 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
If you are dropping everything to do the gears then do a new high stall converter at the same time. You'll be glad you did.
Old Aug 5, 2009 | 08:57 AM
RSchleder's Avatar
RSchleder
Dang, how do you install a whole hole?
Old Aug 5, 2009 | 10:23 AM
makn hp's Avatar
makn hp
Default rear end
ha schleder get a life
To differential
