A/C Issues
Old Aug 7, 2009 | 11:46 PM
Sevenk's Avatar
Sevenk
Default A/C Issues
I replaced the AC compressor a couple months ago on my 98, but it's still acting a little odd. Is it normal on these cars for the AC to come on every time you use the front defog/defroster? No matter what temp I have it set on, the AC light always comes on as soon as I hit the defrost button.
Any ideas? I already have too much $$ wrapped up into the dumb A/C! Thanks!
Old Aug 8, 2009 | 12:13 AM
bestvettever's Avatar
bestvettever
Default AC on with defrost
Hi, the answer is yes. the AC will operate when the system is in the defrost mode.
Old Aug 8, 2009 | 12:26 AM
Sevenk's Avatar
Sevenk
Ok great. The compressor is making some odd noises too, but at least I know that this is normal operation. Odd, no other car I've had did that! Thanks!
Old Aug 8, 2009 | 12:31 AM
bestvettever
Hi, actually most American Cars have operated that way for many years, while most foreign cars usually have a switch that give you the option as to whether to run the AC with the defrost mode or not.
Good luck
Old Aug 8, 2009 | 03:06 PM
Tyke's Avatar
Tyke
If the AC didnt turn on with the defog, the warm air will fog ur windows more...thats what happens in FL cos of th ehumidity, so cold air is the only way to defog it
To A/C Issues
