Security and Limp mode????
Old Aug 10, 2009 | 08:41 AM
x_newfie_x's Avatar
x_newfie_x
Cruising
Default Security and Limp mode????
I was hoping someone could help me, maybe steer me in the right direction. On my 02 Z06 here is the problem I have been encountering.
Car keeps going into security and limp mode. I lose all gauges except for rpm and speedometer. When in this mode I also lose function of the power windows and door locks. I have been having a plug wire that has been working it self off and causing a misfire. Still waiting for the plug wires to get here. Hopefully today they will be in. Could this be causing my problem?
Any help would be greatly appreciated.
Old Aug 10, 2009 | 03:52 PM
BigGun's Avatar
BigGun
A loose spark plug wire would not cause this problem. What do you mean by security and limp mode? Does it say reduced power? You will need to pull and post the dic codes.
Old Aug 10, 2009 | 04:54 PM
x_newfie_x's Avatar
x_newfie_x
Cruising
Yes it says reduced power.
Old Aug 10, 2009 | 05:05 PM
byronhunter's Avatar
byronhunter
Go to the top of the C5 Tech page. "Sticky" Bill Curlee's LONG post. Go down to the section on wiring between the doors and A pillar. Lot of reading but it sometimes causes the problem you have.
Go here:
http://forums.corvetteforum.com/c5-t...tion-long.html
Old Aug 10, 2009 | 06:08 PM
TK6's Avatar
TK6
I would look for any codes by using the DIC first. Maybe it's Column Lock related. Otherwise, the wiring in the door accordian is a likely culprit.
Old Aug 10, 2009 | 07:32 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
X Newfie.. Ive typed my fingers off this week. Please call me PM SENT!
Bill Curlee
Old Aug 10, 2009 | 07:41 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Oh,,,,,,,,,,,read and post your DTCs.
READING YOUR Engine Diagnostic Codes (DTCs)
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open etc…)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes)
If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, C or ;H. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present;
press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET
To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
Here is very good site of DTC definitions:
http://www.gearchatter.com
Make sure to include the H or C suffix!!
Old Aug 10, 2009 | 10:24 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I didn't know about that site...Thanks Bill, excellent information there!
Old Aug 20, 2009 | 10:18 PM
Indiana Vette's Avatar
Indiana Vette
Cruising
I would also like to thank you Bill, for the information and the link to the DTC definitions. I do not need them know but, when I do, I am sure it will help me. Again, Thank You!
To Security and Limp mode????
