will not start - need help
Old Aug 10, 2009 | 11:19 AM
wayrod's Avatar
wayrod
2nd Gear
Default will not start - need help
I have a '99 C5 and it will not start. It went dead at a tfc light and re-started...a week later it went dead again and re-started...the next week it went dead and I had to call a tow. I can start it with starter fluid, but it goes dead. The fuel pump seems to be running...I can hear it in the tank. No codes presently. I did install the CLB...the wheel was locking intermitently...it was a shot...no change. The starter spins, but it is getting no fuel.
Old Aug 10, 2009 | 12:40 PM
torchedvet's Avatar
torchedvet
Im having the same problem. Read my thread. Im going to work on these solutions after work and let you all know how it goes.
http://forums.corvetteforum.com/c5-t...-retarded.html
Old Aug 10, 2009 | 12:51 PM
racingvett's Avatar
racingvett
If you installed the CLB after the CL tripped error codes it will not work correctly as it must be installed while system is clear of the triggers of CL failing.
Most likely the PCM was flashed for the limp mode when CL errors trips which prevents PCM from commanding fuel injectors
Check fuel rail pressure for 58 PSI at idle to see if there is some fuel pump, filter or regulator problem.
Also are the injectors getting 12 volts ?
Old Aug 10, 2009 | 03:41 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
How are you checking the DTC's???????????????? Are you using this procedure??????????
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
There are a couple of things that can cause the PCM to kill fuel. CL issues are one of them.
BC
Old Aug 17, 2009 | 10:52 PM
wayrod's Avatar
wayrod
2nd Gear
Sounds like that could be correct...what is the next step? replace or re-flash?? or something else first?
Old Aug 17, 2009 | 11:16 PM
lucky131969's Avatar
lucky131969
What is your fuel pressure at the rail? Check with key turned to the on positon, but do not start. This will allow the pump to run for 2 seconds. See what type of pressure you have, and ensure there is no bleed down.
To will not start - need help
