Traction Control Message
Old Aug 17, 2009 | 02:00 PM
Roedl's Avatar
Roedl
1st Gear
Default Traction Control Message
Getting periodic message as above, also Service Traction control message, in event computer is bad as I also get 1255 code which I understand might be unrepairable, where can I buy a refurb unit, absfixer does not have any.
Old Aug 17, 2009 | 02:56 PM
87SAM's Avatar
87SAM
A C1255 could be a fatal internal EBCM problem. I would first start by checking the connections at the EBCM. I don’t know who sells refurbished EBCM’s but Gene Culley normally has good process on new ones.
Old Aug 17, 2009 | 04:33 PM
trussme's Avatar
trussme
Default You May Have to buy a new one
New EBCM’s … below is a list of part #s. Check with
Fred Beans or GM Parts Direct for actual price & availability ($650 to $1000)
Part Number: 10343433 All 2003-2004
Part Number: 12216561 All 2001-2002
Part Number: 9367071 All 1999-2000 w/o Control Active Brakes
Old Aug 17, 2009 | 11:46 PM
CP Thunder's Avatar
CP Thunder
www.corvetterecycling.com IF you want a used unit. These guys are great!!!
To Traction Control Message
