code p0410\traction control
Old Aug 11, 2009 | 09:16 AM
marinetech's Avatar
marinetech
6th Gear
Default code p0410\traction control
every so often i will get code p0410 i know its air system but what does this mean.also when running the car with traction control on it runs fine for a min or so then looses power and wont take throttle like its telln the car that there is wheel spin. it will do this at low rpm and keep doing so til i turn off the traction control. any one had this problem?if so help would be greatly appreciated
Old Aug 15, 2009 | 06:09 PM
Quicksilver98's Avatar
Quicksilver98
Default P0410
For the P0410 Code the service manual has you check the air pump, Air pump fuses, air pump relay, blockage in air pump hoses and EVAP solenoid. Do you know if the air pump is operational at all? As far as traction control problem, that should have nothing to do with the air pump problem. If you put a smaller size tire in the rear (lower profile like a 35 series) it will cause this problem. Turning off the TCS will allow you to drive it without the loss of engine power but you have to do it everytime you get into the car. Maybe someone on here knows how to disable it permanetly. But if thats not your problem you may want to find out what is really wrong with it.
Old Aug 17, 2009 | 09:26 AM
marinetech's Avatar
marinetech
6th Gear
Default air pump code
i was told the air pump should be turnned off when tunned with a cam,now i havve developed a mis when u get in the throttle dont no if it has anything to do with the trac control or not,the car has a cam full exhaust an ls6 intake
Old Aug 17, 2009 | 09:27 AM
marinetech's Avatar
marinetech
6th Gear
the tires on the back are 285-30-18
To code p0410\traction control
