c5 z06 vs. c5
i´m wondering
diffrence between 2003/2004 model c5 z06 and c5 m6
for example
gearbox? and diffrential.
brakes?
suspension?
fuel pump/system?
is there any/many changes made on these parts in Z06
if so what?
i see the gearbox has diffirent gears diffr., is te Z gearbox stronger or, are they similuar?
what about fuel pump is that the same?
i´m wondering is the c5 gears as strong as the Z06, or is the Z made stronger?
As for the suspension, i know there are not the same shocks, but is that the only diffrient?
fueling system is identical between Z05 and coupe/convertible, although there were slight changes throughout c5 model years.
z06 has unique shocks, sway bars and springs as far as the suspension goes. slight changes in shock valving between 01, 02+03, and 04 Z06 models.
brakes are the same, except for the color of the calipers and pads
now that said I would like the M12s 5th ( .84) gear in my M6 gear box, and the M6 5th gear ( .74) as my 6th gear. This would make 4, 5 and 6 much closer and usable at high speeds.
And the suspension changes, : what´s the main diffrence in springs and sway bar, is it stiffer or?
what about the weight, where lies those 70kg diffirent between z c5 and c5??
What about stiffness, are they as strong, Can they take the same power and TQ
and the gears are they as strong in both c5 and c5 Z
would it be bad idea to take m6 rather then m12, whith drag race in mind. if you had 402 n/a much TQ
lunching at 5000-55000rpm on slicks...
Look into RPM transmissions or Rockland Standard Transmission
but will the m12 from Z06, hold it because i´ve taken many many good lunches at 4700-5100rpm and not broken anything yet
Are you saying that the Z gearbox is stonger?
The T-56 six speed manual transmission has been used in a wide range of vehicles from General Motors, Dodge, and Ford Motor Company. The transmission was originally designed and built by Borg-Warner, but as of 1998, is built by Tremec, though nothing changed internally[citation needed]. The T-56 has been succeeded by the Tremec TR-6060 transmission in many former T-56 applications, as well as applications requiring greater strength than the T-56 could offer.
Applications
Aston Martin DB7 Vantage, 1999–2003
Aston Martin V12 Vanquish, 2001–2006
Chevrolet Corvette, 1997–2007
Dodge Ram SRT10, 2004–2006
Dodge Viper, 1992–2007
Ford Mustang Cobra, 2003–2004
Ford Mustang Cobra R, 2000
Ford Falcon XR6, XR6T, XR8, F6 Tornado/Typhoon, GT/GT-P 2004–2008
General Motors GM F platform V8 cars, 1993–2002
Holden Commodore 1998–2008
Holden Monaro, 2001-2006
GM M12
2001–2004 Chevrolet Corvette Z06
2004–2006 Pontiac GTO
2004–2006 Cadillac CTS-V
GM MN6
2004–2007 Chevrolet Corvette
GM M10
2005–2006 Chevrolet SSR
2006–2008 Holden VE Commodore
GM MZ6
2005–2007 Chevrolet Corvette Z51
with my MN6 rebuilt with steel shift forks - shot peaned gears) I have many many road racing miles on. and it has been great. Granted I dont do 4700-5200 rpm launches.
if and when the time comes to build a 402 - I am putting a stronger transmission in. Most likely a Rockland Standard.
YET is the key word
Some what. Shot peaned gears, steel shift forks vs aluminum shift forks.
i´m gona use an MN6 gearbox because of the gearing.... whith my setup 402 H/C n´d spec 3 clutch
i´contacted rpm and he wanted to sell my parts for over
$3000 that is not what i had in mind to expensive
, so what should i start whith , try to use it stock, and see how it goes or should i order some parts in it to make it a bit stronger, if so what should i ask for.?
Is steel shift forks and shot peaned gears enough?
or?
here is one of them lunches...
