Which Camshaft??
Old Aug 18, 2009 | 06:34 PM
PewterC5's Avatar
PewterC5
Default Which Camshaft??
Hello,
which camshaft are good for a stock ls1 engine if i onlx change the cam??
and which one are good,if i change the cam and the valvesprings???
Old Aug 18, 2009 | 06:46 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Things like what model year would help. Might want to add this into your sig.
Old Aug 18, 2009 | 06:49 PM
PewterC5's Avatar
PewterC5
it's a 2002 Corvette C5 6speed with a stock LS1 engine
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The stock springs are barely good enough for the stock cam.
ANY cam swap will require better valvesprings.
Old Aug 18, 2009 | 06:55 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
If you do decide to go with a new cam, it is a good idea to at least do Heads too!
A good set of LS6 Heads will flow pretty good for a NA set-up!
You could go with a cam similar to mine 224/228 588" Lift 114 Lobe center - DO NOT go below the 114 Lobe Center, you will have to much "LUMP" to it. Stay w/in the 114 + area as this will also work well for you when you go to Forced Induction!
You can have a smooth idle and plenty of cam, kinda like a sleeper with today's technology!
I hope this helps see my sig below for my progression to where I am at now
Thanks,Matt
Old Aug 19, 2009 | 08:16 AM
AU N EGL's Avatar
AU N EGL
and timing chain Plus a tune.
Old Aug 19, 2009 | 10:04 AM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Originally Posted by PewterC5
Hello,
Feel free to give me a call and I'll be happy to help you with a camshaft selection and the required components.
Seth
205-267-6387
To Which Camshaft??
