I am close to pulling the trigger on a CAM, CNC Ported Heads, Intake and Under-drive pulley, and custom tune. I already have LT headers, High-Flo Cats, X-Pipe and custom exhaust.
My question is would it be smart to upgrade the injectors to help with the additional hardware and horsepower? I was thinking of using svo 30# fuel injectors? Or are the stock injectors enough to handle what I am adding?
Thanks,
Dustinztx
Without specifics, it's hard to say if you'll NEED larger injectors.
But with heads/cam/intake, chances are good you will, and 30# SVO's should suffice on all but the most radical of h/c setups. Getting them before your tune would be smart.
see sig for my mods, I use the svo 30#, I have plenty of fuel and even on the spray its just right. the svo 30# are like having 36-38 # (cant remember exactly) injectors in our C5. Ford fuel rating is different than chevy. Good Luck on your mods!
I would do it up front as well. I incrementally upgraded my car and one of the mods was a FAST and injectors because the previous tune showed the injectors to be maxed out.
