Fuel Gauge Issue
Old Aug 19, 2009 | 02:10 PM
jvest's Avatar
jvest
Default Fuel Gauge Issue
In the past few weeks I’ve had issues with the fuel gauge on my 02 corvette. It will intermittingly go to empty. Sometimes it may go for days and others times it may be just a few minutes. I guess the first thing to do is clean the ground points and if that does help, replace the sensor in the tank. Does anyone have any other suggestion to start on first?
Thanks,
Jim
Old Aug 19, 2009 | 02:20 PM
Cyberdemon's Avatar
Cyberdemon
The fuel sender is probably one of the most common issues people have. Some people have had luck running some techron through the tank and resetting the code via the DIC. I did that the other day and it seemed to eliminate it but I'm sure it will come back at some point.
If you do a search theres a lot of posts on the fuel sender. The full replacement is the most expensive/complex of the fixes, but the Techron/reset trick worked for me.
Old Aug 19, 2009 | 07:07 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree. The Techron is the usual fix for this. I would recommend a bottle of techron once every 3 months or so depending on how much you drive it. Even with the Techron, my '99 would still do this from time to time. There is a recalibration update for the PCM through GM, that I requested be uploaded. From that point on, my issues stopped.
Old Aug 19, 2009 | 07:49 PM
3rdvette@60's Avatar
3rdvette@60
Mine took two full tank treatments of seafoam and now is back to normal.
Old Aug 19, 2009 | 09:45 PM
jvest's Avatar
jvest
Thanks for the help. I'll try the techron first, then replace the sending unit if the techron doesn't resolve the problem.
Thanks again,
Jim
Old Aug 19, 2009 | 09:54 PM
jvest's Avatar
jvest
Do you add the techron as the instructions suggest or would you add a little more to increase the concentration?
Thanks,
Jim
Old Aug 19, 2009 | 10:05 PM
dgrant3830's Avatar
dgrant3830
Personally, I used it as suggested as I didn't want to take a chance of trashing the Cats
Old Aug 20, 2009 | 09:57 PM
jvest's Avatar
jvest
Put the techron in today. So far so good, but holding my breath for a couple of weeks before I start bragging.
Thanks again for the help,
Jim
To Fuel Gauge Issue
