Removing catalytic converters
Old Aug 19, 2009 | 04:10 PM
ianj650's Avatar
ianj650
Default Removing catalytic converters
I'm thinking of removing my catalytic from the exhaust. What could be some of the side effects to the system. Zip or one of them sells some new oxygen sensors that tricks the computer into thinking their still in the system. Has any body else done this mod and can give me some input?
Old Aug 19, 2009 | 04:35 PM
dougbfresh's Avatar
dougbfresh
Why waste your time and effort?
Old Aug 19, 2009 | 04:41 PM
ianj650's Avatar
ianj650
I make long drives six hours or better regularly with it. Through the desert mostly. I get a lot of heat coming up through the tunnel area because of the converters. I want to eliminate the heat issue.
Old Aug 19, 2009 | 04:59 PM
cdnguyred88's Avatar
cdnguyred88
Originally Posted by lucky131969
Insulate...
The smell can be bad at times.
Old Aug 19, 2009 | 05:01 PM
81c3's Avatar
81c3
Well, if you want to keep setting codes on the DIC, have terrible exhaust fumes actually come into the vehicle, like loud occasional backfires and want it to sound like a dump truck on deceleration, then by all means, remove the cats.
Old Aug 19, 2009 | 10:06 PM
tiojames's Avatar
tiojames
Insulate...
Removing the cats will not make that much of a difference. Insulation will.
Old Aug 19, 2009 | 10:46 PM
Corvette Don's Avatar
Corvette Don
Not worth it on a stock car. Buy a tunnel plate for the heat.
Old Aug 19, 2009 | 10:58 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Insulate the tunnel and floor boards with Frost King heat duct insulation and some reflectex foil covered bubble wrap and you will be amazed at the difference in heat rejection and less road noise:
Installation is fairly easy
BC
Old Aug 19, 2009 | 11:30 PM
AlphaKnight34's Avatar
AlphaKnight34
I did a similar mod, replacing my old cats (they ummm, got a hole in them both) with high flow cats, with the option of off road pipes (no cats) I also had dyno runs done, O2 simulators added and tuning. for the effort, there was a negligible increase in HP and torque with the off road pipes installed. Went back to the high flow cats. All in all, wasn't really with it.
Just my two cents
Old Aug 20, 2009 | 11:58 AM
Soul per4mance's Avatar
Soul per4mance
Default cat removal
good thing is that your rpms might climb alittle faster which is good for an all out racer, but for a stock daily driver, there are much more negatives to it. You're going to get alot of popping and burbling upon deceleration, along with the increase smell of exhaust fumes. Not really good to be sitting in traffic on a hot day and smelling that. Why not just get high flow cats?
Old Aug 20, 2009 | 01:15 PM
MattB's Avatar
MattB
A ceramic coated tunnel plate will reduce the heat, and it will add a lot of stiffness to your Vette. Its a good upgrade. It will not completely eliminate it, but you can follow Bill's post and combine that with the tunnel plate to really reduce heat and noise.
Old Aug 20, 2009 | 01:21 PM
Gideon's_Test's Avatar
Gideon's_Test
I had mine removed when the long tubes were installed...Don't miss them. The high flow units are expensive and not worth the bother, in my opinion. Exhaust sounds great without 'em and the smell isn't bad as people suggest...Frankly, it just smells a little rich is all..(and my nose is more sensitive than most)...
Old Aug 20, 2009 | 10:04 PM
Blown427conv's Avatar
Blown427conv
My cats were removed before I got the car and it runs and sounds OK. It does seem a little rich on the exhaust smell and I don't think there is a measureable power gain without them. I'm with the majority on this one, leave them unless you are replacing the whole system with headers etc.
Old Aug 20, 2009 | 10:12 PM
tiojames's Avatar
tiojames
Also a federal violation-muff shops can be fined up to $25,000 and lose their license. For the few HP, it's not worth it.
Old Aug 20, 2009 | 10:53 PM
Jeffwilson34's Avatar
Jeffwilson34
I have no cats on mine and do not notice any smell, I also do not hear and backfires or anything.
Longtube headers, no cats, and Borla Quad tip Stingers and it sounds great.
Just have a tuner turn off the DIC codes for the rear O2's.
Old Aug 21, 2009 | 09:28 AM
rebelheart's Avatar
rebelheart
With todays tech there is no need to go without cats IMHO!
Old Aug 21, 2009 | 06:59 PM
iced98lx's Avatar
iced98lx
I don't have cats, but I also dont' have those issues. Had I not been putting on headers, I would have left mine alone, they do serve a purpose, none of of which are to stop exhaust fumes from entering the car or prevent backfires. Your cats could be clogged if they're getting super hot, but the car will pop a CEL if it gets hot enough. I'd try the insulation first and a tunnel plate... My tunnel still gets plenty warm on long trips without the cats.
To Removing catalytic converters
Old Aug 21, 2009 | 09:15 PM
PewtVette's Avatar
PewtVette
Wrap the inside of the tunnel and the tunnel plate and you will be happy:
Old Aug 21, 2009 | 09:31 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WOW! Nice insulation stuff. What is it and where do you get it?? Thats on my list of must do!
BC
Old Aug 21, 2009 | 11:28 PM
Thalomos's Avatar
Thalomos
Are you talking about a burning type smell after flooring it? I guess I read it wrong, the smell is only if the cats are removed.... meh, guess I have some other problem. I think something might be touching the exhaust.
Didn't mean to thread-jack :P
