Blowing a fuse
Old Aug 21, 2009 | 04:27 PM
Warpy's Avatar
Warpy
Cruising
Default Blowing a fuse
Was checking the fuses for the rearview mirror and vanity lamps when I found
Fuse #2 - Monitored (inadvertent) Load Control (10 amp)
blown.
Replaced it and ......zzzzzzzzzzzap ....blew again. One more fuse, same thing.
Any ideas? This sounds like a hook it up to the stealership diagnostic machine situation, since I am not a good spark chaser. I hate to do that.
No codes showing up. Car runs like a champ. 2003 Z06 with 20K miles.
Old Aug 21, 2009 | 04:44 PM
lucky131969's Avatar
lucky131969
blown.
Benjamin Franklin's definition of insanity was "repeated action with an expected different outcome".....
No dealership analysis machine is going to figure this out. This is no different than tripping a circuit breaker in your home. You keep unplugging appliances on the circuit until it stops tripping.
The loads on this circuit are:
underhood light
L&R mirror vanity lights
Instrument panel compartment lights
BCM
I'd start from the top, since the underhood light connector is most susceptible to corrosion, and unplug it first. I would consider the BCM shorting a remote chance at best(unless it got wet). Keep unplugging/removing lights until it stops blowing the fuse.
Old Aug 21, 2009 | 04:48 PM
Warpy's Avatar
Warpy
Cruising
Thanks Lucky. I'm on it.
Quick noob question. BCM?
Old Aug 21, 2009 | 04:51 PM
lucky131969
Body Control Module....a nice silver box located to the left of the passenger footwell fusebox.....controls all kinds of good stuff.. If the carpet is wet down in the area from a leak, chances are, the BCM got wet too.
Old Aug 21, 2009 | 04:53 PM
Warpy's Avatar
Warpy
Cruising
Yes, so true. Eh, the eternal positive thinker in me.
Kinda like.....what do you call an accordian player with a pager?
An Optimist.
Old Aug 21, 2009 | 04:54 PM
Warpy's Avatar
Warpy
Cruising
Ah, yes. Eh, dry as a bone in that area. I'll do a double double check. Thanks!
Old Aug 21, 2009 | 04:55 PM
lucky131969
Man, Byronhunter must be strokin it....guess I'll post the diagram.....
Old Aug 21, 2009 | 05:12 PM
Warpy's Avatar
Warpy
Cruising
Thanks for the diagram.
Byronhunter? That went over my head.
byronhunter's Avatar
byronhunter
Don't put it all on me!
Old Aug 21, 2009 | 05:15 PM
Warpy's Avatar
Warpy
Cruising
Inside joke. Okay, get it.
Looking at that diagram, any chance that a recent CLB install might be involved?
lucky131969
Sorry.....I've started my weekend early....already on my first Jim Beam/Coke.......I couldn't resist.....
Old Aug 21, 2009 | 10:56 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Shouldn't be, unless you put something back together wrong or knicked a wire.
You typically pull the knee bolster to install a CLB and pull a few fuses and swap out harness under the steering column to keep the pin energized so it does not lock the steering wheel.
Old Aug 22, 2009 | 09:31 AM
rebelheart's Avatar
rebelheart
Always look for a short in the last area you worked in!
Old Aug 22, 2009 | 01:03 PM
Warpy's Avatar
Warpy
Cruising
By process of elimination, I'm down to the BCM being the culprit. Pulled bulbs one by one, disconnected the rearview mirror........still blowing fuses.
All other work is clean. Don't see any shorted out exposed wires.
BCM
Searching for alternatives for a replacement or fix.
Old Aug 22, 2009 | 01:36 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Then you need to pull your codes. The car won't run without the BCM working.
Old Aug 22, 2009 | 02:25 PM
byronhunter
I doubt it's the BCM. Circuit #640 to the BCM is only to monitor the status of that circuit. I'm not saying it's impossible.
Old Aug 22, 2009 | 02:35 PM
lucky131969
BCM
Did you unplug the underhood light..not just the bulb? With the battery disconnected, I would unplug the BCM. If all the bulbs in the circuit have been removed, you should read an open for resistance relative to ground on the load side of the fuse. If you have a short to ground, you need to figure out where the short is in the wiring.
Old Aug 23, 2009 | 02:33 PM
Warpy's Avatar
Warpy
Cruising
Excellent. Did just the bulb routine under the hood. Disconnect the rearview mirror.
Okay, back into the garage.
To Blowing a fuse
