Passenger Side Mirror not working?
Old Aug 23, 2009 | 11:30 PM
PY310L's Avatar
PY310L
Default Passenger Side Mirror not working?
Tried to adjust the mirrors today, drivers side worked fine. Went to click over to the passenger side mirror got nothing? Should I start looking at fuses? Or did the motor burn out? Any help would be greatly appreciated . Thanks
Old Aug 23, 2009 | 11:43 PM
byronhunter's Avatar
byronhunter
Does the window go up and down? Pull the codes and post them here.
Old Aug 24, 2009 | 01:39 AM
DeeGee's Avatar
DeeGee
Check out fuses 30 and 31 on the footwell panel. If they are good I'd pull the rubber gaiter in the door hinge. Check for nicks or chafing and clean and reseat the connector. If the fuse has blown thats also a good place to look as it may have shorted out.
Heres a pic (courtesy Bill Curlee) to show it
Old Aug 24, 2009 | 03:14 AM
PY310L's Avatar
PY310L
Ok, I'll check on that first thing tomorrow. Thanks DEEGee I'll keep you posted..
Old Aug 24, 2009 | 06:50 PM
PY310L's Avatar
PY310L
I was able to check the fuses #30 & #31. Both checked ok, none were blow. I then removed the rubber gaiter to check the connectors. All the wires looked fine, pulled apart the connectors and reconnected. Nothing... Any other suggestions?
To Passenger Side Mirror not working?
