My 1998 Corvette tries to kill itself over any bump on the road. Over train crossings I think it's going to shake itself a part. It has the base suspension and my buddies 2003 Z06 rides better.
Where I live some of the roads are not so great, but I've watched guys with M3's and Porsche's glide over the bumps that I slow down to 15 for - or else my dash sounds like it might fall off. I dodge sewer covers that are sunk into the street by an inch or the car hits them really hard.
The problem is I took it to the dealer for the same problem and asked them to check the shocks. They found a broken front spring, which sure enough was very broken and said my shocks look fine and were not leaking.
I'm still pretty sure it's the shocks, but I just want to make sure it couldn't possibly be anything else before I go and purchase some shocks.
That's a tall order sight unseen. How many miles on the shocks? I would get underneath the car and inspect the suspension for anything bent, loose end links, etc.
Are you saying you replaced the spring and it is no better?
A little bit better. The previous spring had a chunk of it coming off.
Unfortunately I'm unable to do that myself right now. Will probably have to just take to a shop again and see if they can figure it out.
If you are running run craps, ditch em.It will be the best mod for ride comfort you will ever make!
Switching to non-runflats will make the biggest difference, although I have no doubt that replacing your OEM shocks with Bilsteins will have a noticable effect as well.
All of the things you mentioned (train tracks, pot holes, man holes...) I always try to avoid in my car entirely. Remember that a BMW is a sedan and the Porsche has a lot more sound deadening material than our Corvettes do.
If you have over 70k miles, then new shocks are definately a good way to go.
My 97 and my 03Z were two of the tightest cars I have ever driven. The C5 chassis is one of the stiffest in the industry which usually reduces rattles considerably. If you are getting rattles in the dash somebody must have been playing around with it.
Has your car been lowered by chance? Maybe you just arent used to the stiff suspension of a performance car.
Stock suspension.
Pot holes I avoid, manholes I usually avoid, I was just giving examples of when I hit them. Car only has 55k miles but it's getting pretty old. Also it's from PA.
Can't afford to lower the car on these roads in this area. The air dam scrapes enough as it is. It is possible i'm not used to a performance car though.
My only issue is it seems my buddies Z06 rides better than mine over the same bumps.
I found the ride characteristics of my low mileage 00 Coupe too soft and was determined to improve them on a budget...I installed Bilstein Sports, used Z06 composite springs(off a low mileage 04 Z06), Z06 sway bars with metal endlinks and poly bushings...end result is the car handles 100% better than before, and I can go over railway tracks without bottoming out as you described!!! Coilovers are great but the $2k cost is more than most peolpe are prepared to spend....
It's a stretch but there are stories of dealers leaving tha packing blocks on the shocks which limits travel to about an inch and a half. Probably not on your car after all these years but it's worth checking out.
