Mouse in the heater
Any advice would be appreciated.
Dan
My daugther tried a new Envoy a few years back and the dealer kept them parked under the trees at the edge of some woods. Same thing, I turned on the heater to play with it during the test drive. I bet all his new trucks had similar issues. Needless to say she ordered hers
Happens all the time, get them out of there. Also, mice leave urine trails that others will follow so you need to clean things good and spray. I have heard/read they don't like Lavender so a spray with that scent may help.
Dan
The odor was the first clue on a trip to Carlisle for the Kit Car weekend, altough at first I thought it was just coolant overflow. Carlisle is about 150 miles from my home in Fairfax, the weather was unseasonably warm, and by the time my wife and I reached the Fairgrounds, it took on the character of a week-old-roadkilled deer.
The trip back with windows down was from a Twilight Zone script, and pretty brutal ... once back in the driveway, when I began to focus in on the source and had removed the battery and platform, I was able to see a brown shape at the base of the firewall and confirmed it was a critter of some sort.
In order to remove it, however, I had to rig up a probe using a two-foot-long spring steel closet organizer and a barbed hook from my box of deep sea fishing tackle ... the rat was in a late state of decomp (my wife actually blew lunch in the driveway as I removed the remains), and the odor remained until a baking soda solution, white vinegar, and high-pressure hose finally flushed it away ... about 2 hours of work with the probe and the hose.
Not just to share the anecdote here, and trying to be helpful, when I inspected the firewall area where the critter had croaked, I noticed a stiff rubber boot through which wiring is channeled into the dash area and passenger footwell where the in-cockpit fuse box and BCM live ... in my case, the boot was not seated in the firewall, and this was one of the reasons the odor of the dead rat was filling the cockpit ... if that is the case with your car, it could be the avenue the mouse used to gain entry. I confess that when I saw this, I became paranoid about the possibility of a nest and a decomposing litter of abandoned babies, and tore the dash apart to confirm there was none.
So in checking for an entry point, even though it is a minor pain to pull the battery and tray, don't neglet to look there and make sure that boot is intact and seated properly in the firewall ... while you're down there, it's also a good idea to see if you've even had battery acid leakage onto the wiring and connectors below the tray, which is not uncommon among the community of cars still limping along with the OEM Delco or other lead acid batteries.
(I've also got moth ***** in a baggie made from nylon hose that I hang in the engine compartment when I'm putting the car up for a few days in the garage or under a cover in the driveway ... the urban legend is that mice and rats hate the smell ... I can confirm that the odor does keep my wife from getting near the car, but can't promise it will chase away the wildlife.)
,,here are the pictures of the MESS!
They get in thru the HVAC air inlet opening under the windshield cowl:
I actually started the engine and the ENTIRE dash shook. I guess Mice don't like 1040 RPMs
His little feet were sticking out of the rotor blades (click click click click) as the fan coasted to a stop:
MAN,,,,,
,,,what a mess!!!I will just let my buddy prowl the garage!
Thanks,
Dan Brown
Woodinville, Wa.
I have been reading through your posts about this issue as I just got my 00 out of storage from it's winter sleep. For those that don't realize it, vette driving in Ontario or most parts of Canada is strictly a fair weather sport..
I immediately saw evidence of mice all over the outside of the car. Strong odour inside but no activity in the car. When taking a tight corner yesterday, heard a thump and then the fan started ticking..
Thanks to your posts, was able to open this up today quite easily (fan) and remove the little guy before he really started stinking. While washing today I saw his mate scurry away into a nearby field. I think they had just moved in (lack of crap present in the fan and not a big mess).
Regardless, I really appreciate this forum and all of your expert posts and comments, pictures, etc.. This forum is fantastic.
Thanks Again,
Keith
