Broken drivetrain help
Old Aug 25, 2009 | 02:26 AM
Johns C5's Avatar
Johns C5
Default Thanks
It was just the clutch
Thanks for any comments
Old Aug 25, 2009 | 07:43 AM
clif's Avatar
clif
St. Jude Donor '09-'10
Sounds like something in the torque tube... Maybe on of the couplings died? At any rate, you will need to drop the diff and transmission to get to it. Good luck!
Old Aug 25, 2009 | 12:30 PM
SEEYAA's Avatar
SEEYAA
i agree, does sound like a coupler has failed goodluck!
Old Aug 25, 2009 | 12:37 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Just to be different, I'm going with door # 2 and say you lost your gear cluster inside your tranny.
Old Aug 25, 2009 | 02:49 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Well, get the rear end off the ground, first blocking the front wheels of course, fire it up and roll them gently. Get a friend to do this while you are under there listening.
Old Aug 25, 2009 | 03:19 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Sounds like a clutch near total failure to me.
Old Aug 25, 2009 | 03:20 PM
clif's Avatar
clif
in ALL cases, he will need to drop the driveline!
Old Aug 25, 2009 | 04:01 PM
dougbfresh's Avatar
dougbfresh
Sounds like clutch to me too.
Old Aug 25, 2009 | 04:52 PM
redcycle13's Avatar
redcycle13
Sounds like clutch failure.
I had an instant clutch failure about a year ago. It gave no warning signs, but when I dumped the clutch in second gear it just stuck in second and wouldn't come out. I turned the car off for a few minutes, and was able to get it to change gears, but it would never hold any power/load again. Replaced with a new clutch a week later, and problem solved.
Old Aug 25, 2009 | 05:32 PM
Johns C5's Avatar
Johns C5
Thanks to all
Old Aug 25, 2009 | 05:35 PM
clif's Avatar
clif
Keep us posted on how it goes!
Old Aug 25, 2009 | 06:41 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
I'm on the clutch bandwagon with this one.
To Broken drivetrain help
