more electrical problems....Help!!!
Old Aug 28, 2009 | 05:47 PM
99HRDTP's Avatar
99HRDTP
Default more electrical problems....Help!!!
Things began with the passenger window which refuses to roll down.
Next the DIC started autocycling for no reason.
Last week, the fog lights and dashboard lights wouldn't illuminate, but the headlights would.
Today, the headlights popped up when I set the switch to the foglight setting, and the passenger lamp struggled to fully pop-up!!
WTF?!? Any help....Bill Curlee?.....anyone?!?!?!?!
Old Aug 28, 2009 | 06:40 PM
lucky131969's Avatar
lucky131969
Old Aug 28, 2009 | 07:08 PM
cliff_ford's Avatar
cliff_ford
Is the passenger foot well damp?
Old Aug 28, 2009 | 07:51 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I think you have a low battery, bad multifunction switch and you need to beat on the window down relay!
Old Aug 29, 2009 | 07:31 PM
99HRDTP's Avatar
99HRDTP
Not since an overflow from the front drain about 3 years ago. These problems just started.
Mike
Old Aug 29, 2009 | 10:50 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I think you are right Tim!
Old Aug 30, 2009 | 08:18 PM
99HRDTP's Avatar
99HRDTP
I can't get the right headlight to raise all of the way. I tried to disconnect the battery in an attempt to reset things, and the servo kept actuating trying to lower it even though it was all-of-the-way down.
Old Aug 30, 2009 | 08:35 PM
JropTop's Avatar
JropTop
I think its the battery also,you would be suprised the wierd things the car will do with a low,or bad battery,mine played Jingle Bells!
Old Aug 31, 2009 | 05:05 PM
99HRDTP's Avatar
99HRDTP
I hear you, but the Optima red top that is in is less than a year old?!
Mike
Old Aug 31, 2009 | 06:10 PM
tstar's Avatar
tstar
Double check the Battery cable connections... That's worth a shot!
Hold your window down button down and slam the door to see if the window moves then. There's a great Thread in here on the DIY relay replacement for the window relays...
I still suspect your headlight multifunction switch...
Does your right headlight move smoothly with the manual ****?
Tim
Old Aug 31, 2009 | 06:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Read adn post the DTCS. Then we can get down to solving this issue.
BC
Old Aug 31, 2009 | 06:30 PM
tstar's Avatar
tstar
OK Bill's back from Carlisle... I'm bowing out!
Tim
Old Sep 1, 2009 | 06:43 AM
99HRDTP's Avatar
99HRDTP
Tim
I checked the battery connections to no avail. The right headlight opens with the manual switch if I give some upward pressure on it (you can also hear the motor continuing to lower it after the light is closed).
Mike
99HRDTP's Avatar
99HRDTP
BC
Bill,
Checked the DIC. No codes are popping.
Mike
Old Sep 2, 2009 | 05:54 AM
99HRDTP's Avatar
99HRDTP
ttt
To more electrical problems....Help!!!
