all these codes cant be good????
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0481 FC Relay 2 and 3 Control Circuit
P1516 Command vs Actual Throttle Position Performance (TAC Module)
not listed
p0068 hc
p0120 h
p0220 h
u0107 h
C1287 Steering Sensor Rate Malfunction
C1288 h
B2723 PASS-Key Detection Circuit
B2204 Left Window Down Switch Fault
B2206 Right Window Up Switch Fault
B2236 Left Door Lock Switch Fault
B2238 Left Door UnLock Switch Fault
B2282 Battery #1 Fault
B2284 Battery #2 Fault
B2262 Horizontal Position Sensor Fit
B2264 Vertical Position Sensor Fault
U1255 Serial Data Line Malfunction
U1064 Loss of Communications with BCM
1016,1096, and 2286 not listed on site
B2203 Right Window Up Switch Fault
B2205 Right Window Down Switch Fault
B2237 Right Door Lock Switch Fault
B2239 Right Door Un-Lock Switch Fault
B2253 Key Cylinder Switch Fault
B2283 Battery #1 Fault
B2285 Battery #2 Fault
B2263 Horizontal Position Sensor Fit
B2265 Horizontal Position Sensor Fault
B2273 Right Mirror Motor Fault
U1096 Loss of Communications with IPC
2223, 2227, 2229, 2233, 2235, 2243, 2207, 2209, 2287, 2279, u1255, u1016, are also not listed on the site
The car has a 2 bar SD tune, ported TB, and Intake mani, headers, fre flow cats, corsa pace car exhaust, tr6 plugs, 60lb injectors, and a D1SC, with a tune from my speed shop, I believe HP tuners.
If your reading significantly less than battery terminal voltage,,,you will know what to do!
http://forums.corvetteforum.com/c5-t...ch-repair.html
Let us know what you find so we can further guide you.
BC
BC
